Kujo720kittyD21 Posted August 3, 2021 Report Share Posted August 3, 2021 When putting KADE Pistons in a z24 block but using stock camshaft will you still have to cut valve reliefs in the Pistons. The Pistons I'm ordering have a coating on the surface I was hoping not to have to cut into the coating Quote Link to comment
Stoffregen Motorsports Posted August 3, 2021 Report Share Posted August 3, 2021 Well, there's an old saying - want in one hand and crap in the other, then see which one fills up first. You should probably do an engine mock up to verify this. Don't make any assumptions. Quote Link to comment
datzenmike Posted August 3, 2021 Report Share Posted August 3, 2021 Never heard of using DE pistons in a Z24. Have you checked that the pin height is the same as the Z24??? KA24E and KA24DE don't use the same rods. The DE may use a longer or shorter rod??? KA24E have been done many times because both have the same pin height of 34mm. The E pistons produce a 9.5 compression. The DE would be just a hair above the stock Z24 of 8.25. Just what are you after??? Quote Link to comment
Kujo720kittyD21 Posted August 3, 2021 Author Report Share Posted August 3, 2021 I would like to put the ka pistons in my z24 block without having to grind valve relief s in them project is a z24 block and head with ka pistons ka manifold upside down an top mounted turbo side draft carb draw through set up Quote Link to comment
Stoffregen Motorsports Posted August 4, 2021 Report Share Posted August 4, 2021 Ok, trying not to sound like a know-it-all here, but you've said you don't want to grind reliefs in the pistons twice now, but haven't acknowledged any of the replies. Have you done any engine math? Have you compared pin heights? I honestly don't remember if the pin heights are even close, but I do believe it's possible. Do you have your Z24 apart? Do you have a KA piston? Buy one, and take the rod/piston out of the Z24, then take some measurements and do some math. 1 Quote Link to comment
datzenmike Posted August 4, 2021 Report Share Posted August 4, 2021 Get an oversize Z24 pistons that are ceramic coated. Or coat them yourself. 1 Quote Link to comment
