Stinky Posted July 23, 2021 Report Share Posted July 23, 2021 (edited) I am working on a Mercury Villager (a Nissan Quest in disguise). I am trying to replace the front motor mount....grrrr. Lets just say that it has been frustrating. On Monday I went to Oreilly and bought one. Monday afternoon, I returned it and went to Napa to order one. Tuesday, I learned that the one from Napa (overnite from somewheres) doesn't fit either. Before I took it back, I tried bending it to get it to fit....NO-way Jose. I returned it and then ordered one from Autozone. It is a VDP part....it comes from the manufacturer, then to the local store....2 days. Autozone has the bushing (internal rubber part). I almost ordered that too, but didn't. Odd, Napa does not show the bushing in their catalog, but AZ does. On Wednesday, I went to Autozone and ordered the bushing. On Thursday....today. I learned that the Autozone mount doesn't fit either. Their part had bit burrs around the bolt-holes. My grinder fixed that...but the dern thing wouldn't go on/around the frame. I probably coulda fixed that, but what if the spacing was off too...back you go. This is particularly frustrating as I have to almost get the new part on to see if it will actually not fit. You can put them side by side and see that they are dif...but maybe they will fit. All my hopes are set on the bushing being the correct one. If not....my old mount will get welded on. If I can't get it to go in by heating up the circle, and pressing it in....gonna cut the strap and then weld it back together. The problem is the the mount is U-shaped and it goes down on the cross-member under the motor. The U is too wide in places, and then too narrow in others. The mounts all have a dif PN, and the bushing is not the same. The Autozone part had a name on it, the others did not have a PN or any other stamping on them. Today, I got to fool w/my floor=jack. I put a new used ram in it. It sorta works. Simple job, but tomorrow will be the 5th day Edited July 23, 2021 by Stinky 1 Quote Link to comment
KELMO Posted July 23, 2021 Report Share Posted July 23, 2021 What year is this thing? Quote Link to comment
Stinky Posted July 23, 2021 Author Report Share Posted July 23, 2021 96...the deal is that all 3 off the mounts were not bent correctly, so that they matched the cross-member Quote Link to comment
Crashtd420 Posted July 23, 2021 Report Share Posted July 23, 2021 46 minutes ago, Stinky said: 96...the deal is that all 3 off the mounts were not bent correctly, so that they matched the cross-member Are you searching for mercury parts or Nissan? Maybe try the nissan dealer.... Quote Link to comment
Stinky Posted July 24, 2021 Author Report Share Posted July 24, 2021 In this case, Mercury parts are Nissan parts. I have an aversion to the dealer....it is possibly un-warranted. The bushing is in. I'll try to get it in tomorrow. 1 Quote Link to comment
Stinky Posted July 29, 2021 Author Report Share Posted July 29, 2021 I got the bushing in the old mount. I used all-thread and washers, and my ATV wheel tire retaining plate, for the tire-changer and pressed it on. The beast is presently being thrashed by the 3 kids as their DD. 1 Quote Link to comment
