jbirds510 Posted July 19, 2021 Report Share Posted July 19, 2021 I just broke the passenger rear brake adjuster on my 73 620 Anyone in the northern oregon area ( eugene to portland) have 1 they would be willing to part with? Trying to make the DAB show with ist! Quote Link to comment
Ooph! Posted July 20, 2021 Report Share Posted July 20, 2021 Have you taken it apart? there's really not much to break except the side load ratchet spring. If adjusted all the way in they will bottom out and give you the impression of it not working and may be stuck in place. 1 Quote Link to comment
datzenmike Posted July 20, 2021 Report Share Posted July 20, 2021 I broke the knob off the back the interlocking clips hold. 1 Quote Link to comment
bilzbobaggins Posted July 20, 2021 Report Share Posted July 20, 2021 If you broke it as d-mike did, you can tap it and run a bolt with a washer to get you to the show. 1 Quote Link to comment
datzenmike Posted July 20, 2021 Report Share Posted July 20, 2021 I was twenty-something, had no drill, no tap no skillz. All I was good at was breaking stuff. 1 Quote Link to comment
jbirds510 Posted July 20, 2021 Author Report Share Posted July 20, 2021 (edited) 59 minutes ago, datzenmike said: I broke the knob off the back the interlocking clips hold. This. ^ . In my case no doubt was doing it wrong. I may have had a stroke of luck however, assuming a 73 620 has the same adjusters as a 77 620 I went to a yard near me thats known for having older stuff and they had a 620 in it. drum was stuck and they were closing so Im going back with some spray and baby sledge in the morning. @bilzbobagginsgreat tip! plan B..Your way is how it probably should have been made to begin with. Edited July 20, 2021 by jbirds510 Quote Link to comment
datzenmike Posted July 20, 2021 Report Share Posted July 20, 2021 There are right & left adjusters. Get the correct one. Quote Link to comment
620slodat Posted July 20, 2021 Report Share Posted July 20, 2021 Where are you at? I'm just a little west of I-5 where the new Love's truck stop just north of Albany is at. What datzenmike is getting at is there are right and left hand threads. Make sure you get the correct thread. Don Quote Link to comment
datzenmike Posted July 20, 2021 Report Share Posted July 20, 2021 I was thinking that a left could be used on the right side if turned around facing to the front, but then the star wheel adjuster would adjust backwards. Doesn't mean you couldn't just that you would lever the adjuster the opposite direction on the one side. Yes there are L&R adjuster screws and mating star wheels so this can only mean L&R threads. Quote Link to comment
