Revs hanging up on a KA24DE
Finally got the engine running consistently, idle is about 900rpm, can't seem to get it lower without it starting to stumble, advance at idle is 19 degrees but when I blip the throttle the revs go up to 1200-1300 and hang there for 4 seconds or so before backing down to 900.  The throttle cable isn't hanging up anywhere but the revs are.
Does that sound like a recognizable symptom of something?
Thanks
  • Replies 2
26 minutes ago, Drummerboy4as said:
Are you using an auto ECU by chance? I’m trying to diagnose a similar issue and I’m reading auto ECU’s may do this normally.
No, I confirmed that the ECU is from a manual car, since that 1st post I have managed to get the idle down to 800rpm but it still hangs.  After a bunch of reading here, and the Zilvia forum it seems to be something these engines do, some don't have the problem but it is a common complaint.
