shawninvancouver Posted July 12, 2021 Report Share Posted July 12, 2021 i have the two wires in rear side of car where antenna goes, but i now have a new antenna... a black , red , green wire... is there a way to use my switch and make it go up and down? if i put the switch wire to red green it goes up but no way to get it down... how can i wire it to use the switch?? Quote Link to comment
datzenmike Posted July 13, 2021 Report Share Posted July 13, 2021 Try using the red wire. The electric motor may run in reverse. Quote Link to comment
thisismatt Posted July 13, 2021 Report Share Posted July 13, 2021 (edited) If it stops automatically at both ends and there is a wire for up and a wire for down, then you just need to wire in a relay with NC & NO contacts. NO contact connects to the up wire, NC connects to the down wire, and your switch or radio remote or antenna wire is your trigger. NO = normally open NC = normally closed Edited July 13, 2021 by thisismatt Quote Link to comment
