Oilspot Posted July 12, 2021 Report Share Posted July 12, 2021 So one hinge on my tailgate is pretty smashed. Just the piece that's attached to the bed (the tailgate itself was replaced at some point and the hinge piece on it is in good shape). I'd like to find the weld in replacement piece. I spotted a pair of nos hinges ($$$$), but really don't wanna spend all kinds money on this repair if I don't have to. But then again, I don't wanna pass up a impossible part to find and regret It down the road. Are they available out there or should I jump on them? 1 Quote Link to comment
Crashtd420 Posted July 12, 2021 Report Share Posted July 12, 2021 They are not really available other than old stock so ya if you need them buy them.... Take some pics of yours are they fixable.... or are they that messed up? 1 Quote Link to comment
thisismatt Posted July 12, 2021 Report Share Posted July 12, 2021 Plenty of junk beds out there. Just find someone to cut one off for you or bend yours back to shape. 1 Quote Link to comment
datzenmike Posted July 12, 2021 Report Share Posted July 12, 2021 Put what truck you have in your profile and thee year, or say so in the title. Or tell me so I can change it. Having it in the title helps in the future when someone is looking for information on a hinge for a 521??? 1 Quote Link to comment
Charlie69 Posted July 13, 2021 Report Share Posted July 13, 2021 Ebay. Ebay 520 521 Tailgate Hinges Or contact Ted. 2 Quote Link to comment
Oilspot Posted July 13, 2021 Author Report Share Posted July 13, 2021 22 hours ago, Charlie69 said: Ebay. Ebay 520 521 Tailgate Hinges Or contact Ted. Glad to know that's an option. I think I'll prob put the word out and hope to find someone with a trashed bed they can cut the piece out I'm needing. 2 Quote Link to comment
NC85ST Posted July 14, 2021 Report Share Posted July 14, 2021 A picture of what you’re dealing with might be helpful. 2 Quote Link to comment
Oilspot Posted July 15, 2021 Author Report Share Posted July 15, 2021 23 hours ago, NC85ST said: A picture of what you’re dealing with might be helpful. I just need the bed side. The tailgate was a replacement and has a straight hinge piece. 2 Quote Link to comment
Crashtd420 Posted July 15, 2021 Report Share Posted July 15, 2021 14 minutes ago, Oilspot said: I just need the bed side. The tailgate was a replacement and has a straight hinge piece. That's looks like you should be able to just bend it back up and straight ... I was wondering if they were still factory or modified.... I went out to my truck at work to look only to remember the bed is at home..... 2 Quote Link to comment
thisismatt Posted July 15, 2021 Report Share Posted July 15, 2021 Bending it back up and running a new weld bead is going to be a lot simpler than replacing the whole thing. Some heat from a mapp gas torch will help 3 Quote Link to comment
Oilspot Posted July 15, 2021 Author Report Share Posted July 15, 2021 Yeah I was already thinking of pulling the bumper and rear light so that I had a straight shot with a jack from underneath, heating it up with my torch. That's easy enough. But cutting off the distorted unit and welding in a straight one would give it a way cleaner look once done. The trucks pretty straight, and I'm wanting to make it as crisp as possible!!!! 3 Quote Link to comment
Crashtd420 Posted July 15, 2021 Report Share Posted July 15, 2021 37 minutes ago, Oilspot said: Yeah I was already thinking of pulling the bumper and rear light so that I had a straight shot with a jack from underneath, heating it up with my torch. That's easy enough. But cutting off the distorted unit and welding in a straight one would give it a way cleaner look once done. The trucks pretty straight, and I'm wanting to make it as crisp as possible!!!! I would try to fix it first, if the repair doesnt work source a replacement... Beside when would you actually see it even if it wasnt perfect.... Unless your Mr. Bigtanker non of these truck are perfect even ones that are all original.... 2 1 Quote Link to comment
Oilspot Posted July 15, 2021 Author Report Share Posted July 15, 2021 15 minutes ago, Crashtd420 said: I would try to fix it first, if the repair doesnt work source a replacement... Beside when would you actually see it even if it wasnt perfect.... Unless your Mr. Bigtanker non of these truck are perfect even ones that are all original.... Yeah you've got a point. I do plan to use this truck and drive it fairly often. 3 Quote Link to comment
jbirds510 Posted July 15, 2021 Report Share Posted July 15, 2021 I second fixing it, nothing to lose right? 2 Quote Link to comment
Crashtd420 Posted July 15, 2021 Report Share Posted July 15, 2021 47 minutes ago, Oilspot said: Yeah you've got a point. I do plan to use this truck and drive it fairly often. Trust me it's easy to go down the rabbit hole of money with these trucks..... Fix what you need to enjoy it and fix what annoys you later..... Always better to fix while driving and enjoying it vs fixing while waiting to drive it..... 3 Quote Link to comment
datzenmike Posted July 15, 2021 Report Share Posted July 15, 2021 Tell the truth they kind of look like a generic barn door hinge from a hardware store that someone welded in. No one is going to see it, even a tailgater. 3 Quote Link to comment
Charlie69 Posted July 15, 2021 Report Share Posted July 15, 2021 Make both match as far as welds go and no one will know the difference except us. 2 Quote Link to comment
