Rusty Dawg Posted August 19, 2021 Author Report Share Posted August 19, 2021 (edited) Well, it was as simple as replacing the sensor and now I am street legal. Thanks for all the insight. Edited August 20, 2021 by Rusty Dawg 3 Quote Link to comment
Rusty Dawg Posted January 4 Author Report Share Posted January 4 Happy belated New Year's folks. I had all turn signals working on my rig for months, but today I checked them out once again and I noticed that when I engage the right turn signal, both front turn signals flash. This does not happen if I engage the left turn signal and it only happens with the front signals. The rears work regardless of which signal is engaged. What gives? Quote Link to comment
stevecar Posted January 4 Report Share Posted January 4 Check your ground on the front right socket. 1 Quote Link to comment
Stoffregen Motorsports Posted January 4 Report Share Posted January 4 Also, check the bulb. If the glass separates from the metal base, it can cause this. One other thing is the socket itself. Years of corrosion can get in between the socket and the reflector causing the ground to go bad. Sometimes you can gently twist the socket inside the reflector and get it grounded again. I had to do this just last week. 1 Quote Link to comment
