Oilspot Posted July 4, 2021 Report Share Posted July 4, 2021 (edited) So I've got a carb kit coming in tomorrow. Any links, info, etc to help me get this thing back in order. Ie. Passageways critical to clear, Adjustments etc. 71' 521. Nikki 16010 (ugh, that numbers from memory) I've always kinda felt like i need to understand how a specific carb functions to be able to fully clean and rebuild it. And I dont know a damn thing about this unit! Edited July 4, 2021 by Oilspot 1 Quote Link to comment
datzenmike Posted July 4, 2021 Report Share Posted July 4, 2021 Shop rags and towels Dental pick or similar. Carb cleaner spray with straw. (good for blowing out passages if you wear goggles) Large table covered in newspaper and good lighting or headlamp. Toothbrush (used) Both large and small Phillips and slotted screwdrivers Carburetor jet removal tool. (save you grinding down a screwdriver) Needle nose pliers Regular pliers Magnetic pick up tool. Digital camera. Too many pictures is better than too little 2 hours uninterrupted, 4 otherwise. A good kit will have directions for initial setting up. There is very little to wear out inside the carburetor other than the accelerator pump. Mostly it just needs cleaning, second is adjustments. I never take the vacuum secondary apart. I never take the power valve out. If BCDD equipped I don't mess with it. (if it fails to work so much the better) I never adjust the fast idle screw, it's set at the factory. You bend the linkage to change the cam setting. I avoid submerging the carburetor in cleaning solution. You might want to spray the carb down several times before removing it from the intake. Carb cleaner on a rag and toothbrush gets most of the dirt off. On most Hitachi carburetors there is a hollow screw coming up from the bottom that clamps the throttle plate to the carburetor body. It HAS to go back in the same place as it allows intake vacuum up to the power valve. My carburetor had been apart and the screws mixed up and I noticed it. When the front is removed there is a very small brass part on the float hinge that spaces the float away from the glass. Probably on the Nikki. Watch for it. NEVER take the throttle plates or shafts out of the carburetor body. There are 2 BBs in the accelerator pump circuit that act as one way valves. The kit may have new ones but never count on it. 1 Quote Link to comment
Oilspot Posted July 10, 2021 Author Report Share Posted July 10, 2021 Finally got the time to rebuild the carb. Quite the puzzle!!! I'll admit, I got lost a few times, but ended getting it cleaned up and back together. Spent a while scrubbing the manifold/ side of the head trying to get this old girl cleaned up proper. Slowly but surely it's getting there. 1 Quote Link to comment
mainer311 Posted July 10, 2021 Report Share Posted July 10, 2021 (edited) Kinda weird that your truck has this carb. Is it a J16 or L16? 1971 trucks had L16’s with Hitachi carbs in the US market. Edited July 10, 2021 by mainer311 1 Quote Link to comment
Oilspot Posted July 11, 2021 Author Report Share Posted July 11, 2021 2 hours ago, mainer311 said: Kinda weird that your truck has this carb. Is it a J16 or L16? 1971 trucks had L16’s with Hitachi carbs in the US market. When I was trying to figure out what carb was on the truck I ran into a picture of a Nikki and it seemed to match, so I thought that's what I was dealing with. But then I out once I ordered the carb kit (by make model, year) and the kit came for a Hitachi. My mistake! 2 Quote Link to comment
Oilspot Posted July 11, 2021 Author Report Share Posted July 11, 2021 Well shit!!! Cleaning up my work area, I find this🤣. Of course the carb is bolted to the truck. Sometimes I have to laugh at myself when this kinda stupidity happens. 1 Quote Link to comment
Charlie69 Posted July 12, 2021 Report Share Posted July 12, 2021 Put it in the glovebox so you have it if you need it! LOL Quote Link to comment
420n620 Posted July 12, 2021 Report Share Posted July 12, 2021 (edited) Looked at my 71 521 carb and didn't see that bracket. I'm with Charlie, put it in the glove box for now. Can you put in your profile what year and model of Datsun U got. Makes it easier for us members to know what you got. Edited July 12, 2021 by 420n620 add anutter sentence. lol 1 Quote Link to comment
d.p Posted July 12, 2021 Report Share Posted July 12, 2021 Hey mfer start one thread and ask all your questions there. Or don’t I don’t care. 1 Quote Link to comment
datzenmike Posted July 12, 2021 Report Share Posted July 12, 2021 Oilspot, you can start a project datto post on your 521 and I can move all these separate posts into it so nothing is lost. https://ratsun.net/forum/6-project-datto/ 1 Quote Link to comment
Oilspot Posted July 12, 2021 Author Report Share Posted July 12, 2021 (edited) 1 hour ago, d.p said: Hey mfer start one thread and ask all your questions there. Or don’t I don’t care. Sorry bout that man! Been on a bunch of forums where they prefer just the opposite for searchability etc. I'll just start putting everything in my NM521 thread from here on out!!!! I'll update my info with year make etc. on my truck also!!!! And I do apologize for having so many fucking questions. It's been a while since I've had a project I'm so interested in. I'll back off on the posting. Edited July 12, 2021 by Oilspot 1 Quote Link to comment
Charlie69 Posted July 12, 2021 Report Share Posted July 12, 2021 1 hour ago, d.p said: Hey mfer start one thread and ask all your questions there. Or don’t I don’t care. We had the same from d.p when he first started, funny he should say this! 1 Quote Link to comment
Charlie69 Posted July 12, 2021 Report Share Posted July 12, 2021 14 minutes ago, Oilspot said: Sorry bout that man! Been on a bunch of forums where they prefer just the opposite for searchability etc. I'll just start putting everything in my NM521 thread from here on out!!!! I'll update my info with year make etc. on my truck also!!!! And I do apologize for having so many fucking questions. It's been a while since I've had a project I'm so interested in. I'll back off on the posting. Don't concern yourself with d.p we don't! LOL Ask all the questions you want, it is expected here. Quote Link to comment
d.p Posted July 12, 2021 Report Share Posted July 12, 2021 17 minutes ago, Charlie69 said: We had the same from d.p when he first started, funny he should say this! Student becomes the master. Circle of life old man. 1 Quote Link to comment
mainer311 Posted July 13, 2021 Report Share Posted July 13, 2021 “The master” HAHAHAHAHAHA 2 1 Quote Link to comment
datzenmike Posted July 13, 2021 Report Share Posted July 13, 2021 3 hours ago, Oilspot said: Sorry bout that man! Been on a bunch of forums where they prefer just the opposite for searchability etc. I'll just start putting everything in my NM521 thread from here on out!!!! I'll update my info with year make etc. on my truck also!!!! And I do apologize for having so many fucking questions. It's been a while since I've had a project I'm so interested in. I'll back off on the posting. Never apologies for asking questions. Post all you like and post some oictures. 1 Quote Link to comment
d.p Posted July 13, 2021 Report Share Posted July 13, 2021 16 hours ago, mainer311 said: “The master” HAHAHAHAHAHA See how many get this reference….. 1 Quote Link to comment
