angelmanuel Posted July 4, 2021 Report Share Posted July 4, 2021 On a B310, is the cross member for a 4 speed different than for a 5 speed? I am installing a 5 speed in a 4 speed car and cannot get the holes to line up. Quote Link to comment
datzenmike Posted July 4, 2021 Report Share Posted July 4, 2021 They are the same. Try turning the cross member around so that the front is towards the back? Is the rubber isolator backwards? Quote Link to comment
angelmanuel Posted July 4, 2021 Author Report Share Posted July 4, 2021 I tried both of the things you mentioned, no joy. What else can I be doing wrong? Quote Link to comment
datzenmike Posted July 4, 2021 Report Share Posted July 4, 2021 25 minutes ago, angelmanuel said: I am installing a 5 speed in a 4 speed car and cannot get the holes to line up. By any chance are you installing a B-210 dogleg 63A 5 speed? Quote Link to comment
angelmanuel Posted July 4, 2021 Author Report Share Posted July 4, 2021 about half to a full hole out. transmission came out of a B310. Quote Link to comment
datzenmike Posted July 4, 2021 Report Share Posted July 4, 2021 Loosen the engine bracket bolts. That's the parts between the block and the rubber isolators. Might give you a little more wiggle room Quote Link to comment
angelmanuel Posted July 4, 2021 Author Report Share Posted July 4, 2021 will try that tomorrow. Quote Link to comment
KELMO Posted July 5, 2021 Report Share Posted July 5, 2021 Wait, hold the phone. What are you installing this on? What did the 5spd come out of? I have put 5 speeds from 210's (B310) into 1200's with not much issue. Well, not much issue. Quote Link to comment
angelmanuel Posted July 24, 2021 Author Report Share Posted July 24, 2021 it is a 5 speed from a B310 into a B310. It did finally fit. only problem is the transmission is extremely close to the tunnel, maybe 1/16". So now I don't have any doubt that the crossmember is different. Quote Link to comment
