datzenmike Posted October 22, 2021 Report Share Posted October 22, 2021 1/8 might split later. Try an inch of 1/8" on the distributor end and, if it will fit, slip the 1/4" line over it. 1 Quote Link to comment
mainer311 Posted October 22, 2021 Report Share Posted October 22, 2021 Vacuum hose isn't usually reinforced, so you can dip the end in boiling water for a minute and then jam it onto the 1/4" fitting. 2 Quote Link to comment
d.p Posted October 22, 2021 Report Share Posted October 22, 2021 Jam that fucker on there. YOLO 2 Quote Link to comment
datzenmike Posted October 22, 2021 Report Share Posted October 22, 2021 Don't even spit on it. 2 Quote Link to comment
Oilspot Posted October 23, 2021 Author Report Share Posted October 23, 2021 (edited) Picked up that Weber from d.p., ordered some main and idle jets (stock jetting doesn't jive well at 3800ft above sea level), and holy hell the trucks running incredible!!! Just ran all over town, made several stops, and it didn't hiccup once. It's nice to finally be able to consider the truck a driver!!!! A few things I ran into. Fuel filler neck/ hose is trashed! I measured and the filler flange is 2.250". The hose has two bends, not to drastic. Does anyone have a line on a place I could get the exact hose? I guess i could just bend a straight hose but I'm thinking thats a hassle I'd rather avoid if possible. Another something I ran into. When bolting on my license plate, I realized that the Passenger side taillight bulb holder unit is trashed. I hit up Jake and he's not making these. Does anybody have a set they wanna sell. And what piece am I missing on my fuel door, and does anybody have one of those up for sale? Edited October 23, 2021 by Oilspot 1 Quote Link to comment
d.p Posted October 23, 2021 Report Share Posted October 23, 2021 Oh and some fuel filter neck info here: Quote Link to comment
Oilspot Posted October 26, 2021 Author Report Share Posted October 26, 2021 Bump on the fuel door question!!!! This sombitch just loves hangin' wide open... to the point I know it's gonna get folded forward and I'm gonna have to source a new one!!! Quote Link to comment
pidge Posted October 26, 2021 Report Share Posted October 26, 2021 (edited) As for the fuel door. I had a problem on an old truck of mine doin the same thing...I used one of those tiny very strong magnets and it worked just fine. You can even glue/epoxy one side so it stays in place. You may have to shim the magnet (or shave it) to have the door sit flush so do a test fit before you glue it. -Pidge Edited October 26, 2021 by pidge 3 Quote Link to comment
mklotz70 Posted October 26, 2021 Report Share Posted October 26, 2021 You can find those at Home Depot in the hardware aisle. Boring fact for the day.....the locking fuel doors with a finger pull bump were not the factory version....they were done at the dealer or elsewhere. The factory locking door did not have a finger pull bump. 3 Quote Link to comment
thisismatt Posted October 26, 2021 Report Share Posted October 26, 2021 CMS Magnetics if you want to order good magnets online. Not sure how they are doing with covid shortages but this was always my go-to for neodymium magnets. Awesome selection and much better prices than box stores 1 Quote Link to comment
datzenmike Posted October 26, 2021 Report Share Posted October 26, 2021 Also missing the little pull through bumpers. Quote Link to comment
Oilspot Posted October 26, 2021 Author Report Share Posted October 26, 2021 3 hours ago, datzenmike said: Also missing the little pull through bumpers. Do you happen to have a picture of the original setup. I'm fine with doing magnets, but if replication of original is easy enough I'll prob go that direction Quote Link to comment
thisismatt Posted October 27, 2021 Report Share Posted October 27, 2021 (edited) Original has a spring clip and then just rubber bumpers in those holes. The spring tends to break... Edited October 27, 2021 by thisismatt 1 Quote Link to comment
BrothersGarage Posted October 28, 2021 Report Share Posted October 28, 2021 Here's a picture of stock bumpers from my project truck: Here's a stock spring. Looks like it does 3 coils on each side 1 Quote Link to comment
Oilspot Posted November 19, 2021 Author Report Share Posted November 19, 2021 So the truck gets new all new hoses and the heater unit gone through this weekend. I figure I'll just loop the heater hose inlet/ outlet so I can drive the truck while I'm cleaning, painting, etc. I got the gates 18457 to make the S to replace the short hose. The long hose, in the truck now, is just bulk hose and I'd assumed that how it's supposed to be. I figure I'll ask, how was it setup originally? Was the long heater hose a molded hose also? Quote Link to comment
datzenmike Posted November 19, 2021 Report Share Posted November 19, 2021 You can loop together but stick a dowel in there to block flow. This would be the same as shutting it off and not using it. Alright in the winter but in the summer this is a lot of hot water being sent right back into the engine without any cooling. Basically circumventing the radiator. Quote Link to comment
mainer311 Posted November 19, 2021 Report Share Posted November 19, 2021 8 hours ago, Oilspot said: I figure I'll ask, how was it setup originally? Was the long heater hose a molded hose also? Yes, it was. It is also an “S” shape made to exit the heater core to the passenger side, and then turn again to travel along the block to the nipple in the front. Quote Link to comment
Oilspot Posted November 19, 2021 Author Report Share Posted November 19, 2021 29 minutes ago, mainer311 said: Yes, it was. It is also an “S” shape made to exit the heater core to the passenger side, and then turn again to travel along the block to the nipple in the front. so.... another gates 18457, cut/ attached to some bulk 5/8" heater hose!?!? 8 hours ago, datzenmike said: You can loop together but stick a dowel in there to block flow. This would be the same as shutting it off and not using it. Alright in the winter but in the summer this is a lot of hot water being sent right back into the engine without any cooling. Basically circumventing the radiator. Just planning to loop it for the day, hopefully a week tops if I run into any problems cleaning up/ "restoring" the heater box assembly. But good point for anybody looking to bypass for any extended amount of time!!! Is any making the heater on/off stickers? I can tape of the existing one when I paint, but always think it turns out just a little cleaner to fully re spray something completely. 1 Quote Link to comment
Crashtd420 Posted November 19, 2021 Report Share Posted November 19, 2021 58 minutes ago, Oilspot said: so.... another gates 18457, cut/ attached to some bulk 5/8" heater hose!?!? Just planning to loop it for the day, hopefully a week tops if I run into any problems cleaning up/ "restoring" the heater box assembly. But good point for anybody looking to bypass for any extended amount of time!!! Is any making the heater on/off stickers? I can tape of the existing one when I paint, but always think it turns out just a little cleaner to fully re spray something completely. There was someone in the 320 section that made new stickers for his heater box which is similar to the 521. they would probably be the same sticker or atleast close enough.... I'm not sure if he just made his or if he had a couple done..... I'll see if I can find where I saw it.... Quote Link to comment
Crashtd420 Posted November 19, 2021 Report Share Posted November 19, 2021 I have no idea how to link a thread but go to the 320 section in the trucks and look for... New 320 owner, 62? Look at pg 44... I assume you just want the hot cold one.... Quote Link to comment
d.p Posted November 19, 2021 Report Share Posted November 19, 2021 1 hour ago, Crashtd420 said: I have no idea how to link a thread but go to the 320 section in the trucks and look for... New 320 owner, 62? Look at pg 44... I assume you just want the hot cold one.... My man, the .... right corner of any post has a share link, click it and copy the URL and PASTE IT: 1 Quote Link to comment
Oilspot Posted November 19, 2021 Author Report Share Posted November 19, 2021 Okay I've got the whole box out and am working on pulling the valve outta the heater core. I looked at some info on pulling these and have seen that using a dowel to punch them through is the best way of getting them apart. The "snout" on the cylindrical valve has seen better days, but can be cleaned up and salvaged. The threaded hole, used to hold the on and off switch has been mushed up some. I'm gonna need to run a tap through it for sure to be able to hang a bolt through there. Anybody happen to know what size/ pitch threads the hole it's supposed to have? 1 Quote Link to comment
Oilspot Posted November 20, 2021 Author Report Share Posted November 20, 2021 22 hours ago, Oilspot said: Okay I've got the whole box out and am working on pulling the valve outta the heater core. I looked at some info on pulling these and have seen that using a dowel to punch them through is the best way of getting them apart. The "snout" on the cylindrical valve has seen better days, but can be cleaned up and salvaged. The threaded hole, used to hold the on and off switch has been mushed up some. I'm gonna need to run a tap through it for sure to be able to hang a bolt through there. Anybody happen to know what size/ pitch threads the hole it's supposed to have? Well, not sure what is was before, she's a 6-32 now! 4 Quote Link to comment
Oilspot Posted November 24, 2021 Author Report Share Posted November 24, 2021 (edited) I'm got the heater box back from the radiator shop today. They fixed (properly) a job weld patch the PO had done, hot tanked, pressure tested, etc. I did a quick refurb on the box... Daily driver quality (not perfect by any means.) Did new hoses this past weekend, it'll get all new heater hoses, clamps, etc when I put this all back together in the next few days. Hoping my new Jakes/ makes heater boot will show up this afternoon, was supposed to get here yesterday but usps botched that. Edited November 25, 2021 by Oilspot 3 Quote Link to comment
