pidge Posted October 18, 2022 Report Share Posted October 18, 2022 (edited) OilSpot, this is what I’ve got in my 521....I’ve added some measurements as well..... Edited October 18, 2022 by pidge 1 2 Quote Link to comment
pidge Posted October 18, 2022 Report Share Posted October 18, 2022 Round bar stock is 1/2” for the unit that drops the rear tire. If you need some more let me know, but I’m limited. The trucks away for winter. Pidge 1 Quote Link to comment
pidge Posted October 18, 2022 Report Share Posted October 18, 2022 I’m not even sure this is the correct set for this truck, but it came with mine. I hope this helps you a bit. 1 Quote Link to comment
pidge Posted October 18, 2022 Report Share Posted October 18, 2022 While we’re on the topic, anyone know what that symbol is above the “1.5 ton” stamping? At first it looked like a firestone tire logo, but I’m not sure. -Pidge 2 Quote Link to comment
Oilspot Posted October 18, 2022 Author Report Share Posted October 18, 2022 (edited) 1 hour ago, pidge said: I’m not even sure this is the correct set for this truck, but it came with mine. I hope this helps you a bit. Yeah that helps a bunch! If that's the og setup I'd love to find one. But for the time being I can bend one up with a L crank handle out of 1/2" round stock. May have to restore my jack also!!! She's feeling a little dry when cranked!!!! Edited October 18, 2022 by Oilspot Quote Link to comment
datsunfreak Posted October 18, 2022 Report Share Posted October 18, 2022 On 10/15/2022 at 6:04 PM, Oilspot said: Do this usually come apart easily enough???? No, it never does. 😄 Quote Link to comment
Oilspot Posted October 18, 2022 Author Report Share Posted October 18, 2022 19 minutes ago, datsunfreak said: No, it never does. 😄 🤣. I ended up pulling the shifter out of the base. It was easy enough. I could imagine pulling the bottom half assembly turning into more than i bargained for, and I need my truck back on the road asap! Quote Link to comment
Oilspot Posted October 22, 2022 Author Report Share Posted October 22, 2022 Got the carpet in most of the way this morning. Decided to take a break before I come back and clean up the edges. I know my works cleaner when I'm fresh and I don't want to risk over trimming anything and making it look like crap. 7 Quote Link to comment
Oilspot Posted October 26, 2022 Author Report Share Posted October 26, 2022 I know i've seen it on here before, and I've seen where it's for sale, but I can't seem to find the damn seal/ strip things that go into the doors. The ones that the window slides up on and into at the top of the window frame. somebody point me in the right direction please. Mine are trashed, keep falling out, and it's only a matter of time before I close one of the doors and the damn window breaks because it's floppin' around. Quote Link to comment
datsunfreak Posted October 26, 2022 Report Share Posted October 26, 2022 36 minutes ago, Oilspot said: I know i've seen it on here before, and I've seen where it's for sale, but I can't seem to find the damn seal/ strip things that go into the doors. The ones that the window slides up on and into at the top of the window frame. somebody point me in the right direction please. Mine are trashed, keep falling out, and it's only a matter of time before I close one of the doors and the damn window breaks because it's floppin' around. They are all over ebay? https://www.ebay.com/itm/334294276929 There are generic versions that fit also, just need to check the measurements. Quote Link to comment
KELMO Posted October 26, 2022 Report Share Posted October 26, 2022 Since I was doing it anyway and DF beat me to it. This stuff? I have always called it glass run. May still be available from Nissan. May still be somewhat spendy as well. 2 Quote Link to comment
Oilspot Posted October 26, 2022 Author Report Share Posted October 26, 2022 What's currently (kinda) in my truck is metal backed. Is that not whats supposed to be in there? Quote Link to comment
datzenmike Posted October 26, 2022 Report Share Posted October 26, 2022 On 10/18/2022 at 7:36 AM, pidge said: While we’re on the topic, anyone know what that symbol is above the “1.5 ton” stamping? At first it looked like a firestone tire logo, but I’m not sure. -Pidge This... Quote Link to comment
pidge Posted October 27, 2022 Report Share Posted October 27, 2022 Yeah that one Mike. I was just curious. Quote Link to comment
datzenmike Posted October 27, 2022 Report Share Posted October 27, 2022 Doesn't say Nissan so may be a generic jack sold to Toyota, Nissan, Mazda ??? but this one does... 1 Quote Link to comment
pidge Posted October 27, 2022 Report Share Posted October 27, 2022 Yeah the opposite side says Nissan on mine. Quote Link to comment
jagman Posted October 27, 2022 Report Share Posted October 27, 2022 Try looking for widow channel for your door glass. Several companies make it in various sizes. Quote Link to comment
datsunfreak Posted October 27, 2022 Report Share Posted October 27, 2022 (edited) On 10/26/2022 at 8:11 AM, KELMO said: This stuff? I have always called it glass run. The old school domestic guys call it "window channel felt", so that's what I searched. 22 hours ago, Oilspot said: What's currently (kinda) in my truck is metal backed. Is that not whats supposed to be in there? The original ones are metal backed, but you cannot buy that anymore. Even if you buy the "correct" stuff from the dealer, it will just be rubber backed. I bought some from the Courtesy Nissan back in the late 90s, using the 510/521 part number, and it was all rubber backed. They told me at the time the metal backed stuff was NLA and would not be coming back. The metal backed versions do stay stuck in the groove better, so I usually put some 3m weatherstrip adhesive on the rubber backed stuff, then roll the window up while it cures. Seems to work very well that way, and it does not fall down later (like it may if you don't glue it). Edited October 27, 2022 by datsunfreak Quote Link to comment
Oilspot Posted October 28, 2022 Author Report Share Posted October 28, 2022 I guess I'm collecting little bitty trucks for a hobby now. My wife saw this, and long story short we own it now. It's a dodge raider, which is actually a rebadged Mitsubishi Pajero. Things got a 1" shorter wheelbase than a samurai. 6'2" roughly 215lbs. Yeah this makes as much sense for me as the 521! 2 Quote Link to comment
banzai510(hainz) Posted October 28, 2022 Report Share Posted October 28, 2022 (edited) those are great rigs. Common in 3rd world countries and Austraila. I just dont know much on the motors. But there was a episode on Wheeler Dealers(english show) on Motor Trend dont know how the part situations is on these. if plentiful. I know Samurai has a big following and part sources Edited October 28, 2022 by banzai510(hainz) Quote Link to comment
Stoffregen Motorsports Posted October 28, 2022 Report Share Posted October 28, 2022 Shorter than a Samurai? Wow. Quote Link to comment
Oilspot Posted Saturday at 12:51 PM Author Report Share Posted Saturday at 12:51 PM I've been busy for a few months now. Decided to sell my property and move from NM back to Florida so I can hang out with my dad. I swore I'd never move back, but well i guess things change! Anyhow, I got the carpet and seat done. Still needs some finishing work, but that's gonna have to wait. I need the truck to haul shit to the dump etc. and I've run into a dumb problem.... What size studs are on the 521 seat rails, the ones between the sliders and the truck? Not sure if they're standard or metric, fine/ course... 1.00 or 1.25. They're not the same as the 620 rails and the nuts not the same as the ones that secure the slider to the seat rail. (I left the hardware on the 620 sliders i had assuming they were what I needed) as far as i can tell they're not m8x1.25, nor are they 5/16 - 18. are they m8x1.00 or 5/16 - 24? 1 Quote Link to comment
thisismatt Posted Saturday at 03:31 PM Report Share Posted Saturday at 03:31 PM They'll be standard, but I don't know what size 😁 Quote Link to comment
mainer311 Posted Saturday at 07:11 PM Report Share Posted Saturday at 07:11 PM (edited) Yeah, most body-mounted stuff is SAE UNF. Either 1/4-28, 5/16-24 or 3/8-24. Edited Saturday at 07:12 PM by mainer311 Quote Link to comment
