Stoffregen Motorsports Posted July 6, 2021 Report Share Posted July 6, 2021 I have had varying results with DGVs. I can say that most of the dieseling issues I have had have been on non-stock engines. The DGV on my dad's Sunbeam Alpine, the one on my '63 MGB, and the one I recently installed on my friend's Sunbeam Alpine have all worked flawlessly. The many 510s and my 320 with a very hot A12 I have owned have all had dieseling issues. None of those engines were stock. 1 Quote Link to comment
banzai510(hainz) Posted July 6, 2021 Report Share Posted July 6, 2021 open chamber head is more likely to desiel(run on) if one has a W53 or SSS or a closed chamber less chaNCE OF HAPPENING. RUN SUPER 1 Quote Link to comment
datzenmike Posted July 6, 2021 Report Share Posted July 6, 2021 Stock L16 head is 8.58 compression. It's the smallest combustion chamber but technically also an open chamber Closed chamber W53 or SSS head is 8.21 Open chamber L20B head is 7.72 With compression that low no wonder they don't diesel!!! 2 Quote Link to comment
banzai510(hainz) Posted July 6, 2021 Report Share Posted July 6, 2021 open still diesel as my L16 did with a L20b head. its head design I think. the wedge on the closed is less prone to Pinging 1 Quote Link to comment
Stoffregen Motorsports Posted July 7, 2021 Report Share Posted July 7, 2021 Spark plug heat range will affect dieseling too. 1 Quote Link to comment
roadsterdude Posted July 10, 2021 Author Report Share Posted July 10, 2021 Update: The cut-off solenoid arrived yesterday. Installed this morning. The threads are correct, but the fit is VERY tight - almost at an angle since it is up against the electric choke assembly. The 12MM hex fitting interfered with the housing but would turn with a little effort without binding. I did get it seated however and wired, but it would not idle. Ran like crap. Idle would not adjust, so I removed it, re-installed the idle jet ran great. Tried once more since I could have had it in wrong. No joy. It fits but something is very wrong. I put the old idle jet back and re-adjusted the idle. It runs fine and almost does not diesel, but it still does blip over a few times, which cannot be good for it, so back to the clutch lugging cut-off for now. What do y'all think the deal is with the cut-off solenoid? Any experience with this? PN 43928.060B Quote Link to comment
datzenmike Posted July 10, 2021 Report Share Posted July 10, 2021 Does it click when power is applied? Quote Link to comment
Stoffregen Motorsports Posted July 10, 2021 Report Share Posted July 10, 2021 Yeah, it needs to be wired for the car to run. When you turn the key off, it kills power and closes the valve. They do fit very tight against the choke. But they do fit. 1 Quote Link to comment
roadsterdude Posted July 11, 2021 Author Report Share Posted July 11, 2021 Great reminder to double check my wiring. I was getting a voltage drop on the jumper I had hooked up from the choke. I re-wired both the choke and the solenoid and boom - problem solved. Thanks guys! 2 Quote Link to comment
