shawninvancouver Posted June 24, 2021 Report Share Posted June 24, 2021 I have not been able to get horns to work - no power up to horn + power wire.. i have power on the button on steering wheel.. trying to find the greens going to the relay but can not locate them.. is this the relay that i have the red arrow??? this relay has no male spades on it.. only a black wire covering holding some wires that i cant see what thye are - the wires are burried behind other relays and wire plugs... fsm shows this as the horn relay.... Quote Link to comment
banzai510(hainz) Posted June 24, 2021 Report Share Posted June 24, 2021 (edited) the horn button is most likely the switchable ground trigger for the relay. as it dont need a big wire to energise the relay. the relay contacts will be higher power for the horn to work. so if you say the horn wire has 12volts then IM not sure. then maybe it would be more like a cig light circut were 12volt is on the socket all the time then you hit the cig lighter and it grounds. but to me thet is still a switchable ground type circut lights on most 70s Jap cars are POWER is there all the time (on all 3 contacts)then a ground get put on the one of the 3 pronges and the lamp comes on Edited June 24, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 24, 2021 Author Report Share Posted June 24, 2021 i got ya... my problem is that i just cant get to the relay to test it or find the horn wires in the harness area.. what else can i do?? Quote Link to comment
shawninvancouver Posted June 24, 2021 Author Report Share Posted June 24, 2021 here is the relay.. how in the world do i ever get this out.. Quote Link to comment
shawninvancouver Posted June 25, 2021 Author Report Share Posted June 25, 2021 when i touch my test light to the green wire from horn on wheel it lights up and when i press horn button it goes off... is that correct or not..?? Quote Link to comment
datzenmike Posted June 25, 2021 Report Share Posted June 25, 2021 Sounds right. There's 12v on the far end, comes through a relay coil and the horn button grounds it. This energizes the relay and closes the contacts sending power to the horns. You should hear the relay click when you use the horn button Quote Link to comment
shawninvancouver Posted June 25, 2021 Author Report Share Posted June 25, 2021 i do not hear the relay click... unless my ear needs to be right beside it... does it sound like relay is dead??? and how do i get out??? there is a philips screw up there and its rusty.. i put bp blaster on it.. but if i strip it im screwed.... one chance i guess... Quote Link to comment
