banzai510(hainz) Posted July 11, 2021 Report Share Posted July 11, 2021 unless the black wire from the Pertronix dont make it back to ground. a good ground would ck the coil if good or bad. I never seen a bad coil myself in 30yrs on my Datsun Quote Link to comment
1lo620 Posted July 11, 2021 Author Report Share Posted July 11, 2021 Ok I can't get it to fire. So I am safely assuming that the Petronix Set up is toast. So I will order one of those and hope that solves the issue. Then I get the joy of replacing the Petronix ignition. Any suggestions on where to order one from Hainz gave me a part number. Quote Link to comment
banzai510(hainz) Posted July 12, 2021 Report Share Posted July 12, 2021 https://www.newegg.com/pertronix-1741-ignition-conversion-kit/p/N82E16889163060?nm_mc=KNC-MSNSearch&cm_mmc=KNC-MSNSearch-_-Tune-Up+and+Ignition+Parts-_-Pertronix-_-89163060&source=region&msclkid=37beee41d95a1ac3b8448ead993d61e8&Item=N82E16889163060 https://shop.advanceautoparts.com/p/pertronix-1741-ignitor-datsun-4-cyl-1741/10110651-p?c3ch=PLA&c3nid=10110651-P&adtype=&product_channel=Online&store_code=&msclkid=17051159e4d71098914971b5a526dd9e&utm_source=bing&utm_medium=cpc&utm_campaign=b_pla_all_performance%2Fparts_performance%2Fignition%2Fstarting%2Fcharging_gen_gen_all_pros_aap_us_all&utm_term=4581046485356580&utm_content=Bing_PLA_Performance Parts_Performance Ignition%2Fstarting%2Fcharging_Ignition&gclid=17051159e4d71098914971b5a526dd9e&gclsrc=3p.ds if your magnet ring is OK I would just leave it in there as the magnet can fall out of the ring and your kinda fucked unless you glue them back in ring Quote Link to comment
1lo620 Posted July 14, 2021 Author Report Share Posted July 14, 2021 Ok so why I wait to get my Petronix. I got a volt meter gauge. (Actually had one in my box of goodies) so how do I hook it up. ? Quote Link to comment
datzenmike Posted July 14, 2021 Report Share Posted July 14, 2021 One side to ground the other to an ignition switched fuse. Use thick wire to reduce voltage drop. Green or Black is usually ground, Red is 12v. Quote Link to comment
1lo620 Posted July 17, 2021 Author Report Share Posted July 17, 2021 Ok got my new Petronix yesterday. So if I get off early enough today. I am going to attempt the switch to the new one. Hainz said to leave the old magnet in there if It is fine. I am ok with that. Less I have to screw with the better. So let you know what becomes if it. Hope it will run. If not it goes into the shop to get fixed. Quote Link to comment
1lo620 Posted July 17, 2021 Author Report Share Posted July 17, 2021 Ok so new ignition in and it started, but minute I let go of the key it dies. Held the key for a second until starter started to grind and it ran again until I let go of the key....now what is up with it. ? Quote Link to comment
datzenmike Posted July 18, 2021 Report Share Posted July 18, 2021 Ballast resistor not wired properly or broken 1 Quote Link to comment
1lo620 Posted July 18, 2021 Author Report Share Posted July 18, 2021 Ok this is the wiring I have right now. Can you tell by looking if what I have is correct. I know it is tough to tell since it is kind of a rat nest. How can you tell if ballast is bad? Quote Link to comment
datzenmike Posted July 18, 2021 Report Share Posted July 18, 2021 Take the wires off the ballast. Test the top one in the picture with a test lamp. It should light when the ignition is turned to ON. Test the bottom wire in the picture. It should light when the ignition is turned to START. Put the top wire back on the ballast. Put the test lamp on the bottom terminal of the ballast. It should light dimly when the ignition is turned to ON. I'm expecting that you will get nothing. Quote Link to comment
1lo620 Posted July 18, 2021 Author Report Share Posted July 18, 2021 Ok I tested as you said. The top wire tested bright when key is on. Also the lower ballast post was bright when I put the top wire back on the top. And when I put the lower wires back on the whole system lite up bright until I put the red coil wire back on then it went dim.. So I would assume that the ballast is ok since I am getting power to it when the only wire on it is the top one. Quote Link to comment
1lo620 Posted July 18, 2021 Author Report Share Posted July 18, 2021 Got it running actually drove it. Seems to miss a bit. But nothing crazy.. Well thanks for all the help. I am sure I will be back. But again I do appreciate the help and patience. 2 Quote Link to comment
banzai510(hainz) Posted July 19, 2021 Report Share Posted July 19, 2021 might have to retime the ignition with a timing light. PS soem times the Only runs in start is the key wires in back its corroded and soemtimes wiggleing the connector fixes it 1 Quote Link to comment
banzai510(hainz) Posted August 4, 2021 Report Share Posted August 4, 2021 is this running now?!!!!!!!!!!!!!!!! Quote Link to comment
]2eDeYe Posted August 4, 2021 Report Share Posted August 4, 2021 It's running, he took off into the sunset until next time 🙂 Quote Link to comment
banzai510(hainz) Posted August 5, 2021 Report Share Posted August 5, 2021 wish people would at least say something . Thanks I got it running. after waliking thru this for 3 pages!!!!!!! 2 Quote Link to comment
thisismatt Posted August 5, 2021 Report Share Posted August 5, 2021 23 hours ago, banzai510(hainz) said: is this running now?!!!!!!!!!!!!!!!! On 7/18/2021 at 4:42 PM, 1lo620 said: Got it running actually drove it. Seems to miss a bit. But nothing crazy.. Well thanks for all the help. I am sure I will be back. But again I do appreciate the help and patience. 🤷♂️🧐🤔 2 Quote Link to comment
420n620 Posted August 5, 2021 Report Share Posted August 5, 2021 (edited) 4 hours ago, banzai510(hainz) said: wish people would at least say something . Thanks I got it running. after waliking thru this for 3 pages!!!!!!! have noticed that he's only here for him self. If you've gotten this far in the thread. See pic. Edited August 5, 2021 by 420n620 Quote Link to comment
banzai510(hainz) Posted August 5, 2021 Report Share Posted August 5, 2021 thanks Matt my mistake Quote Link to comment
1lo620 Posted August 9, 2021 Author Report Share Posted August 9, 2021 I did post that I got it running Hainz. Sorry if you didn't see that. I appreciate all the help I got from everyone. 1 Quote Link to comment
