shawninvancouver Posted June 21, 2021 Report Share Posted June 21, 2021 (edited) ok..so here is whats going on... checked all fuses... only fuse with no power are headlights - as they were not on.. so all fuses worked.. horn does not work, windsheild wipers click, washer, clicks, no fan, no no turn signals no dome lights.. and no guages,, no fuel volts temp etc.. all dead here are some photos of wires .. relay under drivers feet.. rest in the steering colum... does black need to be somewhere or grounded? does red go to black connectors?? wire off from signal stem... could there be one thing that is causing al this?/ a fuse a relay???? any ideas... Edited June 21, 2021 by shawninvancouver Quote Link to comment
shawninvancouver Posted June 21, 2021 Author Report Share Posted June 21, 2021 could it be a fusible link? i have 2 by firewall... only one gets power when key is to power position... Quote Link to comment
