shawninvancouver Posted June 13, 2021 Report Share Posted June 13, 2021 what after market pump would work? can car run on manual pump only and pull fuel though a dead electric pump? or do i need to chop out old electric pump? can i just take out old pump and test it and if it works but wont work in car are there relays? fuses? etc and if so where and color thanks Quote Link to comment
datzenmike Posted June 13, 2021 Report Share Posted June 13, 2021 Does your electric pump work or not. Find out first. Check Black/White wire to pump. Try with ignition on and also try in start position. There are two relays. Quote Link to comment
shawninvancouver Posted June 14, 2021 Author Report Share Posted June 14, 2021 bad pump - after looking under previous owner already bypassed it... Quote Link to comment
datzenmike Posted June 14, 2021 Report Share Posted June 14, 2021 Same design as the 720 truck electric pumps. Quote Link to comment
