Valvebounce Posted June 10, 2021 Report Share Posted June 10, 2021 Today I picked up my headlight buckets from the electroplaters. My original ones were bent from a frontal, so I picked out the best from a box of rusty old spare crap. Gave it a mega soak in acid and scrub with a small wire brush first. (The player turned me away the first time, said they were too rusty) I got them back today all shiney and gold. Naturally i was super excited to get them reassembled. (Its been a stumbling block for ages in the reassembly process) But it seems like one of my headlights wont fit the bucket. (A high beam) am I missing something? (I am pretty tired) I also saw some buckets say koito type 1, and some say Koito type 2. I really thought they were all the same? What am I doing wrong? Quote Link to comment
Valvebounce Posted June 11, 2021 Author Report Share Posted June 11, 2021 Okay, I had another crack at this while less tired. It appears the type 1 are the high beam, and the type 2 are the regular headlights. They must be different to stop mongs from fitting high beam lights into the regular bulb spots. It was remarkably fiddly putting the assemblies back together. With the bulbs secured into the buckets, I couldn't hook up the spring. Might have been different without the bases being screwed to the car. Quote Link to comment
Datfish Posted August 10, 2021 Report Share Posted August 10, 2021 I just gave up for the night working on my 620 on the same problem. Also has been a holdup for me. My truck has three buckets marked "Koito Type 1" and one marked "Koito Type 2". I am about to put two high beams on the Passenger side (RH here) and one high on the side nearest traffic. Would love to see what someone has on an original car. Was searching this topic when I found your thread. Quote Link to comment
Valvebounce Posted August 11, 2021 Author Report Share Posted August 11, 2021 So type two go on the outside. And type one on the inner. I'll take a picture of mine and post it if you like. I worked out where the adjusters had to go based on the screw driver notches in the grill. 1 Quote Link to comment
Datfish Posted August 14, 2021 Report Share Posted August 14, 2021 Thanks, yeah, someone screwed the pooch on my truck and added a third "type1." 1 Quote Link to comment
Valvebounce Posted August 18, 2021 Author Report Share Posted August 18, 2021 Since this thread has now helped someone, I figured I'd add some pictures to make the next person it helps life a bit easier again. Left side, 1 Quote Link to comment
Valvebounce Posted August 18, 2021 Author Report Share Posted August 18, 2021 Right side, Quote Link to comment
Valvebounce Posted August 18, 2021 Author Report Share Posted August 18, 2021 And as said, the position of the adjusters is dictated by the screw driver notches in the grill. Also, the base plates are identical. They just get screwed on the opposite way up. 1 Quote Link to comment
