apachiestrike95 Posted June 10, 2021 Report Share Posted June 10, 2021 So I purchased a long tube header for my 720 pickup but it Doesn’t clear the 4x suspension in the front, but I do have a 620 with a single cam ka and was wondering if a z24 long tube will fit on a ka24e Quote Link to comment
datzenmike Posted June 10, 2021 Report Share Posted June 10, 2021 People have swapped the cast manifolds by doing a little grinding to align the holes. All bets off on steel pipes. Quote Link to comment
apachiestrike95 Posted June 14, 2021 Author Report Share Posted June 14, 2021 On 6/9/2021 at 8:32 PM, datzenmike said: People have swapped the cast manifolds by doing a little grinding to align the holes. All bets off on steel pipes. so if i grind the ports on the z24 header it should fit on the ka24e Quote Link to comment
apachiestrike95 Posted June 14, 2021 Author Report Share Posted June 14, 2021 On 6/9/2021 at 8:32 PM, datzenmike said: People have swapped the cast manifolds by doing a little grinding to align the holes. All bets off on steel pipes. the header i purchased for it is a pacesetter Quote Link to comment
datzenmike Posted June 14, 2021 Report Share Posted June 14, 2021 You could on a cast manifold there's lots of material. A header is a lot thinner. Quote Link to comment
