banzai510(hainz) Posted July 11, 2021 Report Share Posted July 11, 2021 (edited) turn mixtue in out till runs the best. but i think 1.5 to 2.5 tourns out from bottom . but seen worse Edited July 11, 2021 by banzai510(hainz) 1 Quote Link to comment
matrophy Posted July 11, 2021 Author Report Share Posted July 11, 2021 1 hour ago, Madkaw said: How many turns out on the the mixture ? 1-3/4 roughly 1 Quote Link to comment
Jitenshakun Posted July 11, 2021 Report Share Posted July 11, 2021 Trick with a carb is they feed and need the setup that matches the engine. While the same engine is similar - they aren't exact. It's ok the ask for baselines, but don't be shocked if you need something different than the other guy. 1 Quote Link to comment
DucTrip9 Posted July 11, 2021 Report Share Posted July 11, 2021 Just installed the 32/36 dgev on my 86 720. I'm at 5200' above sea level. Running rich, dieseling when shut off and high idle. Just ordered the high altitude jet kit and hope to apply some of the above info to get a more efficient tune...soon. Thanks for the info. 1 Quote Link to comment
datzenmike Posted July 11, 2021 Report Share Posted July 11, 2021 Sounds like the choke may not be shutting off. On a warmed engine take the top off the air filter and look at the choke flap it should be fully open and in the vertical position. 1 Quote Link to comment
A guy named Rick Posted July 23, 2021 Report Share Posted July 23, 2021 (edited) On 6/27/2021 at 6:19 PM, Charlie69 said: Here is the Baseline jetting chart. Remember the carb started life as a DGAV. My jetting is the fifth carb down, the 32/36 DGEV. Exactly like that, and I'm experiencing week feeling acceleration, but like I was saying I have vac leak to fix. Hey OP, how'd you go about installing the AFR gauge? I want to put one on my truck to help tune the carb. BTW, my elevation is less than 100 feet, and no dieseling out at all when shutting off Edited July 23, 2021 by A guy named Rick 1 Quote Link to comment
matrophy Posted July 23, 2021 Author Report Share Posted July 23, 2021 1 hour ago, A guy named Rick said: My jetting is the fifth carb down, the 32/36 DGEV. Exactly like that, and I'm experiencing week feeling acceleration, but like I was saying I have vac leak to fix. Hey OP, how'd you go about installing the AFR gauge? I want to put one on my truck to help tune the carb. BTW, my elevation is less than 100 feet, and no dieseling out at all when shutting off The AEM kit comes with the correct Bosch O2 sensor although, rumor has it that there is one on Amazon that works just as well. After installing the new O2 sensor, it's just a matter of mounting the gauge, running the cable from the 02 sensor to the gauge and power and ground. You need to add a fuse inline per the instructions. If you want to collect data you need an Rs232 to USB adaptor and some logging software 1 Quote Link to comment
Madkaw Posted July 23, 2021 Report Share Posted July 23, 2021 Here’s my jetting . I need to install a bigger air corrector on the secondary side . Probably go to a 180 . 1 Quote Link to comment
datzenmike Posted July 24, 2021 Report Share Posted July 24, 2021 36 minutes ago, matrophy said: The AEM kit comes with the correct Bosch O2 sensor although, rumor has it that there is one on Amazon that works just as well. After installing the new O2 sensor, it's just a matter of mounting the gauge, running the cable from the 02 sensor to the gauge and power and ground. You need to add a fuse inline per the instructions. If you want to collect data you need an Rs232 to USB adaptor and some logging software You have to calibrate it (or at least mine did) and every year? or 6 months. It doesn't run out of the box but it's easy to do. I think you have to have the O2 sensor out in the free air. It reads the oxygen level in the air and remembers it. 1 Quote Link to comment
A guy named Rick Posted July 24, 2021 Report Share Posted July 24, 2021 (edited) 42 minutes ago, Madkaw said: Here’s my jetting . I need to install a bigger air corrector on the secondary side . Probably go to a 180 . What elevation are you at, and also any mods to the engine or is it stock? Edited July 24, 2021 by A guy named Rick 1 Quote Link to comment
matrophy Posted July 24, 2021 Author Report Share Posted July 24, 2021 5 minutes ago, datzenmike said: You have to calibrate it (or at least mine did) and every year? or 6 months. It doesn't run out of the box but it's easy to do. I think you have to have the O2 sensor out in the free air. It reads the oxygen level in the air and remembers it. My understanding is that his version will have some sort of message on the display if it needs to be re-calibrated. It didn't require calibration at first though 2 Quote Link to comment
Madkaw Posted July 24, 2021 Report Share Posted July 24, 2021 54 minutes ago, A guy named Rick said: What elevation are you at, and also any mods to the engine or is it stock? I’m in Indiana - so not much elevation . Stock rebuild . Pistons maybe 10 over - I can’t remember . Spark plugs look perfect . 1 Quote Link to comment
A guy named Rick Posted July 24, 2021 Report Share Posted July 24, 2021 So I might possibly need to jet up in the mains too huh 1 Quote Link to comment
A guy named Rick Posted July 24, 2021 Report Share Posted July 24, 2021 On 7/10/2021 at 7:17 PM, matrophy said: 1-3/4 roughly I am sitting at 1-3/4 now after fixing vac leak. It should probably be mentioned too that I capped off the vac lines to the EGR too now, so no T off of the vacuum advance line. 1 Quote Link to comment
