davis911s Posted May 7, 2021 Report Share Posted May 7, 2021 We put 16 aftermarket rims on my sons truck and now have a pulsing at the brake pedal when you apply the brakes. The rims are mag style with mag style nuts and crush washers, properly torqued. And torqued slowly up 5 ft/lbs at a time and rotated and shook tire between each. As recomended by the tire shop. We have rotated the tires around and have the same issue. We have put old steel rims back on and issue goes away, so we know it is in the rims/tires not in the brake drums etc. The rims ARE NOT Hub-centric. This where I think my problem is. On the front there is actually a very large gap between the hub of the truck and the rim. (like an inch gap) I do not know if there are hub rings for the front spindle on a 620?? But with the 6 nuts torqued down I would think this would hold it? The tires are new and they put balancing beads in them so not to ruin the look of the rim. Maybe balance them and put actual weights inside the rims so they aren't seen? Any ideas aside from having to ditch his new tires and rims???? Quote Link to comment
]2eDeYe Posted May 7, 2021 Report Share Posted May 7, 2021 Sounds like you need to bore the wheels to clear the hubs. Quote Link to comment
davis911s Posted May 7, 2021 Author Report Share Posted May 7, 2021 the bore on the wheels is way larger than the hub Quote Link to comment
datzenmike Posted May 7, 2021 Report Share Posted May 7, 2021 Put 3 of the steel ones on and change one mag at a time to find out if one is causing the trouble. I suppose one of the mags might be bent or perhaps a tire is out of round. Weights can compensate for this when spinning on a balance machine but when rolling on the ground it's a different story. Quote Link to comment
]2eDeYe Posted May 7, 2021 Report Share Posted May 7, 2021 40 minutes ago, davis911s said: The rims ARE NOT Hub-centric. This where I think my problem is. On the front there is actually a very large gap between the hub of the truck and the rim. (like an inch gap) I do not know if there are hub rings for the front spindle on a 620?? But with the 6 nuts torqued down I would think this would hold it? Any chance you can get a picture? Quote Link to comment
davis911s Posted May 7, 2021 Author Report Share Posted May 7, 2021 I can't see how to insert photos Quote Link to comment
davis911s Posted May 7, 2021 Author Report Share Posted May 7, 2021 https://www.facebook.com/photo.php?fbid=3921050901343078&set=p.3921050901343078&type=3 Bolts are not centered or anything in this photo, this photo was just to show how much gap between hub was and bolt depth. I have long ET studs Quote Link to comment
datzenmike Posted May 8, 2021 Report Share Posted May 8, 2021 f/b.... oh man.... Quote Link to comment
davis911s Posted May 8, 2021 Author Report Share Posted May 8, 2021 Sorry, only way I could figure out how to post the photo. I'm going to get the rims actually balanced vs the balancing beads to rule that out. Quote Link to comment
]2eDeYe Posted May 8, 2021 Report Share Posted May 8, 2021 How about the lugs you are using? Those look like you need mag specific shanks. Quote Link to comment
EDM620 Posted May 13, 2021 Report Share Posted May 13, 2021 I had brand new steel rims put on my F150 for the past winter, and found 2 were out-of-round as balancing would never solve the problem. Chances are quite good you have at least 1 rim out-of-round. Like DatzenMike says, put on the known good steels and one at a time add or swap out your aftermarket rims. You'll know absolutely which is the culprit(s). BTW, if you bought them used, PO could have hit a curb or pothole hard enough to alter the rim without more visible damage. My brand-new steelies were probably dropped in shipping. Quote Link to comment
