Sage Alcantar Posted May 5, 2021 Report Share Posted May 5, 2021 So recently I did some searching around on the internet for an SR20 to fit in my 75 620 and I noticed that there are different types of sr20s,, as far as red top, black top, or blue top, does it Matter which one I get to fit in to the 620 or is it the same kind of fab work all the way around? Quote Link to comment
datzenmike Posted May 5, 2021 Report Share Posted May 5, 2021 Has to be an import SR engine. The domestic model is FWD and won't fit. Quote Link to comment
5t341tH Posted May 6, 2021 Report Share Posted May 6, 2021 all the SR20det RWD will fit with the kit. Also, it is quite an involved swap so be prepared for it. 1 Quote Link to comment
Sh00bs Posted May 6, 2021 Report Share Posted May 6, 2021 i know of black and red top, havent heard of blue top? they should all be the same, just make sure it's an SR20det. USDM sr20's like mentioned above are technically the same block but that's about it... came in sentra's i think ? they're junk. Quote Link to comment
datzenmike Posted May 6, 2021 Report Share Posted May 6, 2021 I believe the engine mounts are on the front and there is nothing on the sides of the block for RWD. In addition the CAS/distributor is driven out the rear of the head, placing it in the firewall of a RWD vehicle. 1 Quote Link to comment
Valvebounce Posted May 14, 2021 Report Share Posted May 14, 2021 The fwd sr20 has a different bellhousing pattern than the rwd ones. 1 Quote Link to comment
Valvebounce Posted May 14, 2021 Report Share Posted May 14, 2021 Red top was S13. Silver top was s14 And black top came from S15. The s14s had VVT. The s15 motors had the T28r (ball bearing) turbo. 1 Quote Link to comment
5t341tH Posted May 16, 2021 Report Share Posted May 16, 2021 On 5/14/2021 at 4:13 PM, Valvebounce said: Red top was S13. Silver top was s14 And black top came from S15. The s14s had VVT. The s15 motors had the T28r (ball bearing) turbo. none of that is true 1 Quote Link to comment
Valvebounce Posted May 19, 2021 Report Share Posted May 19, 2021 Okay. Well its accurate based on the Nissan silvias I've seen here in NZ. The s14 motor in my 620 has vvt. And the cam cover was raw aluminium. We never got the KAs here. Quote Link to comment
Eric Posted May 29, 2021 Report Share Posted May 29, 2021 (edited) On 5/15/2021 at 1:13 AM, Valvebounce said: Red top was S13. Silver top was s14 And black top came from S15. The s14s had VVT. The s15 motors had the T28r (ball bearing) turbo. Red top from s13, non VVT Silver top is non existing as far as i know S14 and S15 both had black tops. There is a blacktop with a notch and a black top without. The notch is VVT. The s15 blacktop has smaller holes for the coil packs. The blacktops have T28 turbo's The s15 has ball bearing turbo's But all black tops are available as non turbo as wel. You need a RWD sr20, no FWD or AWD, they wont fit because no RWD gearbox will fit those engine blocks. any more info @5t341tH? Edited May 29, 2021 by Eric Quote Link to comment
Valvebounce Posted May 31, 2021 Report Share Posted May 31, 2021 I have an s14 motor which had a raw aluminium cam cover. It was removed from a facelift s14 which was imported from Japan by a friend. (He removed it to fit an RB30det) Another friend had a Mazda b1600 flat deck with the exact same engine. (His was the reason I decided to build an sr 620) Perhaps I should add these engines are DE, not DET. Quote Link to comment
