BlueBird Coupe tach wiring
Hello I've been mostly a lurker but finally working on my coupe i got from japan. Im having trouble recognizing this tach. I've searched the regular diagrams but there seems to be different connectors from the harness. It is a L16 with pertronix conversion and 3 ohm coil
Link to post
  • Replies 3
Well that clearly shows it connected to the + side of the coil. I've had several inductive tachs and they are connected in line between the coil - and the points in the distributor.
Link to post
