Stoffregen Motorsports Posted April 30, 2021 Report Share Posted April 30, 2021 18 hours ago, datzenmike said: Fucking environmental crap. Carburetor cleaner used to clean carburetors back in the day. I rebuilt my '70 Dart AFB using Gunk that you mix with water. When I was done my hands were sore from chemical burns. Tried some (new formula!!!!) in the 90s and it was a waste of time and money. Bring back the old days when gas was GAS and everyone was either male or female. There was no gay-ass lite beers and girly wine coolers. When if your feelings were hurt well too fucking bad ya whiny cunt. Asking for a coffee was simple and fast... black or cream? When Canadians weren't sorry all the time. Well put. Try raising young kids with these new rules. Every single day, something comes up that I have to tiptoe around in explaining a situation to my kids, or dealing with the schools or other parents. I almost got into a fight at my little boy's baseball game a couple years ago when I said to nobody in particular "can someone go and smack my kid, because he sure ain't paying attention!" I was joking, but one parent took it literally and called me out with "you should be a better father and we don't hit our children." First thing, telling someone they are a bad parent is grounds for execution. And then you also need to have a sense of humor. Douchebag... 2 Quote Link to comment
datzenmike Posted April 30, 2021 Report Share Posted April 30, 2021 In the day it wouldn't need to be pointed out but today people jump on anything to wallow in 'holier than thou' righteous indignation. Carried too far, it's what road rage is today. Douchebag indeed! 1 Quote Link to comment
banzai510(hainz) Posted May 1, 2021 Report Share Posted May 1, 2021 idle jet could be plugged then the mixture setting a the base of the carb might need to be adjust and then timed. I 2 Quote Link to comment
gene knight Posted May 6, 2021 Report Share Posted May 6, 2021 i had same issue with the b210 i bought from azhitman here in phoenix, it ran great and i took over to brakes plus to have them bleed brakes for me, when i got it back it barely ran and i figured it was gas tank needed to be flushed, did that then it would not run, i checked plugs and they were dirty and coated with gas/oil, so i changed those, changed plug wires, changed cap n rotor still no run, so i checked for wire connections, vacuum lines, nothing so i had carb rebuilt nothing, so as i was installing carb back onto intake i notice oil leaks at valve cover so i checked and found out bolts were loose, so i bought a new gasket and after i took off cover 4 push rods were bent and someone tried to adjusted it to get it to barely run when i picked it up, i asked azhitman about it and he said it was running great when he had it and when i bought it so i didn't question it anymore and i bought 5 new tires for it also after i got it from azhitman, so it seems that someone at brakes plus over revved it numerous times and bent push rods then adjusted valves and they could not bleed brake system also, so luckily i had a extra motor and replace bent rods then reset valve clearance and bam fired right up and ran like a champ, then i after that i sold it. 2 Quote Link to comment
