Exhaust Brass Nut
RLJ
  • Replies 4
The 510 nut is 20602-A7100 but I don't know if brass or bronze or what. Probably just steel.
I got some for my L16 exhaust manifold from a fastener shop. They are longer at 5/8" or around 15-16mm long but I also replaced the broken studs with longer ones. They probably were stainless and the extra length made up for the lack of strength that stainless has.
20602-A7100 is discontinued.
Can find brass ones through hardware supply but not the tall ones.
Like you said not sure if the originals I’m seeking were brass or bronze but they didn’t seize to the studs overtime.
Get the thread size or take one with you to a fastener store. Get longer SS.
Hell the studs that were on the L16 manifold only had threads where the nut was protecting them. Above the nut where the flange was it eroded down like a tooth pick.
