ADEN AUTO Posted April 23, 2021 Report Share Posted April 23, 2021 i just bought an older nissan forklift with a j15 motor has rod knocking ,looking for parts , bearings crank ect , whats avalible? Quote Link to comment
datzenmike Posted April 23, 2021 Report Share Posted April 23, 2021 With luck only the bearing is bad. Next luckiest is just the bearing and crank and least luckiest is bearing, crank and rod needs replacing. Well a J13 crank will work so (probably) the J13 rods will too. But you have to find one. As it is a lift truck likely Nissan still has them for rebuilds. 1 Quote Link to comment
ADEN AUTO Posted April 23, 2021 Author Report Share Posted April 23, 2021 Can anyone recomend a good parts source for engine parts? Quote Link to comment
datzenmike Posted April 23, 2021 Report Share Posted April 23, 2021 Not recommending, but there are lots to choose from out there. You will likely want to re-bore and go to an over size piston. A crankshaft can be turned down and an oversize rod bearing used if you can't find a J13/15 crankshaft. https://www.ebay.com/itm/Fits-Nissan-Datsun-J15-engine-kit-620-521-forklift-pistons-gaskets-valves-cam-/150950991795 https://www.ebay.ca/itm/173473252532?hash=item2863cfc4b4:g:BTkAAOSwY1xbc0iF&vxp=mtr https://www.heavydutykits.com/product/nissan-j15-overhaul-kit-forklift-application/ 1 Quote Link to comment
Stinky Posted April 24, 2021 Report Share Posted April 24, 2021 rockauto.com you'll have to find out what that motor corresponds to in a car. I don't know. Mike does though If you get a PN...you can do a search on the web and the rockauto site. 1 Quote Link to comment
datzenmike Posted April 24, 2021 Report Share Posted April 24, 2021 Mexican, Central and South American 510s had J15s, I think but no vehicles in US came with them. 1 Quote Link to comment
zed1 Posted April 24, 2021 Report Share Posted April 24, 2021 Once you tear down the engine and determine what you need, please post a list. Some forum members has parts stashes or have resources that can help you. I rebuilt my J13 with a combination of Nissan Forklift parts and BMC B-Series parts. https://www.flickr.com/photos/53116286@N07/albums/72157624963500879 Keith 1 Quote Link to comment
bananahamuck Posted April 24, 2021 Report Share Posted April 24, 2021 J15 is basically a j13 that has been bored out.. same size everything except piston size 1 1 Quote Link to comment
MikeRL411 Posted April 25, 2021 Report Share Posted April 25, 2021 Too bad you're not near Long Beach CA, there are several forklife rebuild faciities there. I visited one looking for engine thermostat housings for my RL411. No sucess but the foreman gave me several good suggestions. Look in your neighborhood yellow pages for forklift repair ststions. You may find one. 1 Quote Link to comment
ADEN AUTO Posted April 25, 2021 Author Report Share Posted April 25, 2021 Thanks for the help i will let you know what i need when i get it out and torn down 1 Quote Link to comment
Chopper Jim Posted April 26, 2021 Report Share Posted April 26, 2021 Try forklift salvage yards also. We got parts from a yard in Phoenix a couple years ago now. They gave us a pallet full to choose from. Then took the pallet back to them with what we didn't use. Chopper Jim 1 Quote Link to comment
m610 Posted October 27, 2022 Report Share Posted October 27, 2022 I just finished rebuilding a J-15, also from a Nissan forklift. The #1 bearing was almost gone and the engine was leaking oil like crazy. I found most parts locally (Sacramento, CA), and a local shop repaired the crank. Now if I could only get it to fire. (A subject for another thread.) Quote Link to comment
