Goemon Posted April 14, 2021 Report Share Posted April 14, 2021 1 Hour, a 2" floor flange, 2" rigid black pipe, threaded on one end, washers, a die grinder, drill press and a puller. Tape shim to flange, mark pattern, remove shim, center punch and drill. It worked good on mine. 4 Quote Link to comment
Goemon Posted April 14, 2021 Author Report Share Posted April 14, 2021 Nice & clean. Time for new parts, OEM locking washers are on the way. Seals & bearings next on the list. 2 Quote Link to comment
Goemon Posted April 14, 2021 Author Report Share Posted April 14, 2021 I am 2nd or 3rd owner. I have had this for 34 yrs and suspect it has 4-500K on the bearings I am swapping frames due to a hole and converting a Longbed frame into a KC frame. Whoever owned the Cali donor frame must not have known about the threaded holes in the drum for removal. They bent the dogshit out of them 5 Quote Link to comment
]2eDeYe Posted April 14, 2021 Report Share Posted April 14, 2021 Nice tool. 😄 1 1 Quote Link to comment
Crashtd420 Posted April 15, 2021 Report Share Posted April 15, 2021 17 hours ago, Goemon said: 1 Hour, a 2" floor flange, 2" rigid black pipe, threaded on one end, washers, a die grinder, drill press and a puller. Tape shim to flange, mark pattern, remove shim, center punch and drill. It worked good on mine. Great idea... 1 Quote Link to comment
Goemon Posted April 20, 2021 Author Report Share Posted April 20, 2021 Thanks guys. It took longer to think it up than to make it. New OEM Locking washers from Nissan came in today. Now looking for TIMKEN Bearings & Seals, Fixen up my Bessie's new rear end. I have had her since she was 8. 2 Quote Link to comment
Goemon Posted May 8, 2021 Author Report Share Posted May 8, 2021 KOYO JAPAN !!!!!!!! Real Shit. A 720 tank will fit 78-79 KC or Standard Cab. 1 Quote Link to comment
Goemon Posted May 8, 2021 Author Report Share Posted May 8, 2021 Greaseable for her protection........ Quote Link to comment
banzai510(hainz) Posted May 8, 2021 Report Share Posted May 8, 2021 Spicer is the Bomb. Best there is. trying to find 510 half shaft ones!! 1 Quote Link to comment
gene knight Posted May 10, 2021 Report Share Posted May 10, 2021 you should mass produce those axle removal tubes, i would buy 1 for sure cuz im going to swap out drums to disc brakes from silvermine motors and will need to replace axle bearings/ seal when i do it Quote Link to comment
Goemon Posted May 28, 2021 Author Report Share Posted May 28, 2021 You can get the pcs. at your local Home Depot or plumbing supply house. It may be better to bush it down to 1-1/2" pipe, I used 2" You still will need a 2" floor flange. Just a drill , die grinder, I used an axle shim to mark the bolt pattern onto the floor flange, centerpunch & drill slightly oversize. It cost me 26 bucks to make, @ 10 bucks an hour, you are adding another 20-30 bucks to the tool, then there is shipping, if I make them........Datsun guys are tightwads, I know, I am one....LOL This was the best idea I could come up with that would not damage anything in the process. Putting it in any kind of arbor or hydraulic press did not seem like it would be good for the backplates, although several people have said that is the way they did it, I stuck closer to how the manual sez. The reason I did it was because of the fucked up Cali backplates on the replacement frame were worse than my rust belt GA backplates. If anything, this could be a tool that gets sent from town to town once I am finished with it. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ When I am done, Pay shipping & 10 bucks and it's yours to sell to the next guy when you are through with it. I can always make another, as long as I don't go senile first....LOL Anyway, that way it will only cost 10 bucks + shipping to the next guy. The way I box stuff, the box will make several trips before having to be retired. I have gas pump computer boxes that have been from Cali & back 4-5 times I hope to be done with it in a few more weeks....I learned how to electroplate Nickle, so I am on that $16.00 investment on the rods, plating all kinds of shit kick right now............ The wrench was from my first vehicle with a tag, KZ 400, the only thing I have left from her. Not even pictures, Don't even know what year it was anymore.....76? I have some mean ass scars when I got hit by the car that terminated my bike, I was 17. Quote Link to comment
