Lucas Grey Posted April 11, 2021 Report Share Posted April 11, 2021 Hello! I've posted a topic on this before but i'm realizing that I might have to replace the shocks in the rear along with the springs to get a higher ride height. I bought T3 coilovers for the front and am still deciding on what spring rate I am going to get (most likely going with 200). The rear of the car is very low and I am looking to raise it a couple of inches just so that the rear of the wheel is not rubbing when I put people in the back of my car. Does anyone know of good springs or a certain spring rate along with shocks that I could put in? I saw online that they have bags for the datsun pickups for the rear, is it worth trying bags? Quote Link to comment
datzenmike Posted April 11, 2021 Report Share Posted April 11, 2021 Someone must have cut the spring to be that low. Get a new stock replacement set or a set from a 210 in a from a wrecking yard. Or maybe rubber spacers... https://www.amazon.ca/Superior-18-1901-Donut-Spring-Spacer/dp/B00029K20W Shocks don't affect ride height. Some gas charged shocks might push up with 20-30 pounds but not enough to make much difference. Those look new. Quote Link to comment
Lucas Grey Posted April 12, 2021 Author Report Share Posted April 12, 2021 3 hours ago, datzenmike said: Someone must have cut the spring to be that low. Get a new stock replacement set or a set from a 210 in a from a wrecking yard. Or maybe rubber spacers... https://www.amazon.ca/Superior-18-1901-Donut-Spring-Spacer/dp/B00029K20W Shocks don't affect ride height. Some gas charged shocks might push up with 20-30 pounds but not enough to make much difference. Those look new. I've been searching for wrecked datsuns over the area with not much luck. Do you happen to know the spring rate or an aftermarket brand that I could buy them from? Quote Link to comment
datzenmike Posted April 12, 2021 Report Share Posted April 12, 2021 If you make some careful measurements of one of your rear springs I can work out the spring rate. I need the number of full, and any remainder of coils not touching each other or their mounting points. The exact thickness of the wire. The diameter of the coil... outside to outside is fine. The one below looks like 7 1/2 coils Quote Link to comment
Lucas Grey Posted April 12, 2021 Author Report Share Posted April 12, 2021 10 minutes ago, datzenmike said: If you make some careful measurements of one of your rear springs I can work out the spring rate. I need the number of full, and any remainder of coils not touching each other or their mounting points. The exact thickness of the wire. The diameter of the coil... outside to outside is fine. The one below looks like 7 1/2 coils I'll try and get those measurements as soon as possible. I was reading this article and I was wondering if I could just use those 280sx springs? The article also mentions Rockauto coil springs. I'm looking for a much higher ride and comfortable ride so not interested in matching the old springs at all. Quote Link to comment
datzenmike Posted April 12, 2021 Report Share Posted April 12, 2021 Lets find out what you have first. Someone may have cut them to get lower. Shortening any spring makes it stiffer. If this is so the original spring will put you back at the stock height and softer ride. Quote Link to comment
