Rishi Posted April 6, 2021 Report Share Posted April 6, 2021 73 Datsun 510 with a Sr20det how to Wire up original Tachometer Quote Link to comment
MikeRL411 Posted April 6, 2021 Report Share Posted April 6, 2021 Question or statement ? 1 Quote Link to comment
Rishi Posted April 8, 2021 Author Report Share Posted April 8, 2021 On 4/6/2021 at 10:37 AM, MikeRL411 said: Question or statement ? I have a Datsun 510 with a Sr20det I need help wire up factory Tachometer Quote Link to comment
Draker Posted April 8, 2021 Report Share Posted April 8, 2021 There were two factory tachs, which one do you have? 1 Quote Link to comment
Rishi Posted April 8, 2021 Author Report Share Posted April 8, 2021 What do I have to look for to find out Quote Link to comment
Draker Posted April 8, 2021 Report Share Posted April 8, 2021 What color is the tach needle? Quote Link to comment
Draker Posted April 9, 2021 Report Share Posted April 9, 2021 From what I understand the DET motor is coil on plug. Tagging @Icehouse he's got a handful of these, in 510s. Quote Link to comment
datzenmike Posted April 9, 2021 Report Share Posted April 9, 2021 Early tachs were white needle but switched to orange. Both were inductive and had to be wired in line, or in series, between the coil and the distributor. The later tachs were all orange needle and used a single wire to the coil negative terminal. It was common to paint the needle the newer orange color. The needle color aside there were series or parallel tachs. 2 Quote Link to comment
MikeRL411 Posted April 9, 2021 Report Share Posted April 9, 2021 16 hours ago, datzenmike said: Early tachometers were white needle but switched to orange. Both were inductive and had to be wired in line, or in series, between the coil and the distributor. The later tachometers were all orange needle and used a single wire to the coil negative terminal. It was common to paint the needle the newer orange color. The needle color aside there were series or parallel tachs. Even earlier tachometers for the roadster had a side driven spur gear on an extended distributor shaft. It drove an inductive cup like the speedometer. Instead of wheel or driveshaft rotation it showed distributor rotation which was directly indicative of the engine RPM. 2 Quote Link to comment
