720_Jeff Posted April 1, 2021 Report Share Posted April 1, 2021 Adding my last two reports. Results are very similar, so pleased about that.  For the 2019 test, I did absolutely nothing. Just drove it in and tested. This year, changed cap/rotor/plugs, it was about time and nearly identical reports 🙂   2 Quote Link to comment
scremmy Posted April 3, 2021 Report Share Posted April 3, 2021 Has anything been done to the truck? I am moving somewhere that will require emissions testing and I need to know if I am gonna have to undo some of the things to mine in order to legally have it registered haha 1 Quote Link to comment
datzenmike Posted April 3, 2021 Report Share Posted April 3, 2021 Depends on where. Some just have to pass the tail pipe sniff test, others have to pass a visual test. 1 Quote Link to comment
scremmy Posted April 3, 2021 Report Share Posted April 3, 2021 12 minutes ago, datzenmike said: Depends on where. Some just have to pass the tail pipe sniff test, others have to pass a visual test. I know it's just the tail pipe sniffing that it has to pass, that's for sure haha There are only 2 counties in Idaho (currently) that require emissions testing, and they're not super thorough about it 1 Quote Link to comment
datzenmike Posted April 3, 2021 Report Share Posted April 3, 2021 That's not much to go on. If you are going somewhere that only has to pass the tail pipe readings then have it in good tune, have your EGR working and if the truck came with a catalytic converter make sure it's there or at least be ready to replace it for a new approved one. 1 Quote Link to comment
720_Jeff Posted April 3, 2021 Author Report Share Posted April 3, 2021 This truck is totally stock.  It must pass visual and does since its all stock.  A few years ago, replaced spark plug wires.  This time did cap/rotor,plugs.  Oil was changed around 1k miles ago. Since it sat for such a long time, maybe 3 months due to Covid conditions, it sputtered a bit when driving.  Some SeaFoam and a few tanks of premium along with mostly highway driving.  I'm in California, so every two years 😞 1 Quote Link to comment
McFerg Posted May 2, 2021 Report Share Posted May 2, 2021  On 4/3/2021 at 1:29 PM, 720_Jeff said: This truck is totally stock.  It must pass visual and does since its all stock.  A few years ago, replaced spark plug wires.  This time did cap/rotor,plugs.  Oil was changed around 1k miles ago. Since it sat for such a long time, maybe 3 months due to Covid conditions, it sputtered a bit when driving.  Some SeaFoam and a few tanks of premium along with mostly highway driving.  I'm in California, so every two years 😞 Hey 720_Jeff I'm in LA county. My Stock Carb seems to be in Limp Home mode.  You know of anyone that has put a Weber carb on? Do you think it would pass our smog check here in CA?  2 Quote Link to comment
datzenmike Posted May 2, 2021 Report Share Posted May 2, 2021 I believe to pass emissions you must also pass a visual inspection and a Weber certainly won't. I can think of at least 3 critical emissions systems that would be disconnected by using one. ATC, AIS and EGR 1 Quote Link to comment
Charlie69 Posted May 2, 2021 Report Share Posted May 2, 2021 Weber and California is NO. Quote Link to comment
720_Jeff Posted May 3, 2021 Author Report Share Posted May 3, 2021 Like others have said, Weber and 720's don't go together in California. It won't pass visual. I've read stories about folks using a Weber and original air cleaner that has been modified for the Weber. That helps disguise the Weber and might pass visual at a sloppy shop. Some have claimed to have done so successfully.   From this webpage that sells Weber, it seems to claim the 8000 series is legal for certain engines in a Toyota.  http://www.redlineweber.com/carb-kits/auto/toyota-truck/  Bottom line, to my knowledge, there is no CARB compliant carburetor for the 720's in California, well beyond the stock Hitachi. Quote Link to comment
