frankendat Posted March 21, 2021 Report Share Posted March 21, 2021 Reviewing the thread posted above, to evaluate a K24E oil pump, I am in need of clarification. If the top edge extends above the lip of the "pear" hole on the pump, then it is the higher volume pump, correct? Pasted below is the pump in question. To double down make certain, the interior cylinder of a KA24E is larger (again see DatzenMike's thread above) Has anyone measured the cylinder? Quote Link to comment
frankendat Posted March 22, 2021 Author Report Share Posted March 22, 2021 Did I get it right? Quote Link to comment
Ooph! Posted March 22, 2021 Report Share Posted March 22, 2021 I read the post you linked and it says you should be able to see the rotor vanes near the top in the high volume pump. There is a picture of it and a regular pump in that thread Quote Link to comment
frankendat Posted March 22, 2021 Author Report Share Posted March 22, 2021 Thank you, I looked at the pictures in the attached thread and....am....fairly certain, that I have a KA24E oil pump (it was labeled as such where I bought it. The rotor vanes on my pump extend above the lip of the pear shaped opening. I am just looking for clarification, before time to get a refund expires. Quote Link to comment
datzenmike Posted March 23, 2021 Report Share Posted March 23, 2021 Yes that is the high volume pump. The internal rotors a longer rather than larger. I don't have the length but the KA are 13% longer. Quote Link to comment
Ooph! Posted March 24, 2021 Report Share Posted March 24, 2021 datzenmike on Rockauto there are several different pumps for the 280zx turbo, would all of them be high volume? Quote Link to comment
datzenmike Posted March 24, 2021 Report Share Posted March 24, 2021 Only the turbo automatics. Get the D21 Hardbody KA24E or KA24DE oil pumps. That's all they had were high volume. The '89-'90 S13 (240sx) KA24Es also had them but not the KA24DEs. (they had an internal oil pump) Quote Link to comment
frankendat Posted March 24, 2021 Author Report Share Posted March 24, 2021 4 hours ago, datzenmike said: Yes that is the high volume pump. The internal rotors a longer rather than larger. I don't have the length but the KA are 13% longer. Thank you DatzenMike!!!! It was advertised as a KA24E pump, I wasn't sure the rotor went up high enough. Good News! Quote Link to comment
