jreddy Posted March 14, 2021 Report Share Posted March 14, 2021 Hi Guys looking for location of resistor for heater fan and a fleabay link to the correct part or maybe i need complete unit ,any help would be gr8t....... regards the slow sd22 1 Quote Link to comment
datzenmike Posted March 14, 2021 Report Share Posted March 14, 2021 It's on the fan box upper left with the two screws holding a plug with blue wires. Doubtful anyone sells them other than a wrecking yard. Take it out and twist the broken wire ends together will probably get it working till you find another. 1 Quote Link to comment
jreddy Posted March 14, 2021 Author Report Share Posted March 14, 2021 Thanks For prompt reply Mike will try that ,at work at the moment so will check tomorrow, 1 Quote Link to comment
KELMO Posted March 15, 2021 Report Share Posted March 15, 2021 Original part # is 27150-03W20 # is for US models but I would guess it should be the same in other markets. 1 Quote Link to comment
Charlie69 Posted March 15, 2021 Report Share Posted March 15, 2021 Kelmo what is the fitment of part #27150-62W20? Quote Link to comment
Charlie69 Posted March 15, 2021 Report Share Posted March 15, 2021 This might be a little cleare image. Quote Link to comment
datzenmike Posted March 15, 2021 Report Share Posted March 15, 2021 9 hours ago, KELMO said: Original part # is 27150-03W20 # is for US models but I would guess it should be the same in other markets. This is for up to '83 model year. '83 and up had 4 speeds. 1 Quote Link to comment
KELMO Posted March 17, 2021 Report Share Posted March 17, 2021 'Posted Monday at 09:01 AM Kelmo what is the fitment of part #27150-62W20?" 720 12/1983 and up. OP lists vehicle as an SD22. In the States this motor ran up to the end of 1982 (10/1982). 1 Quote Link to comment
