Jbone32 Posted March 14, 2021 Author Report Share Posted March 14, 2021 Yea seems like it was the problem the whole time .Whats crazy is it was parked it running perfect..changed water pump and it blew out and started blowing white smoke once it started..maybe excess pressure from new water pump?...wierd Quote Link to comment
mainer311 Posted March 14, 2021 Report Share Posted March 14, 2021 26 minutes ago, datzenmike said: So over heating has probably warped the head. Oh well' Usually sold as one gasket fits all. The L20B is 86mm cylinder bore, same as the L18. Felpro is good enough. 85mm Quote Link to comment
datzenmike Posted March 14, 2021 Report Share Posted March 14, 2021 Yes 85mm WTH did I say? Quote Link to comment
banzai510(hainz) Posted March 15, 2021 Report Share Posted March 15, 2021 (edited) I never seen a head gaske pop on all the cylinders like that before. You sure your intake gasket on the other side is tight as it can suck in water thru there, esp to the 2 inner or all cylinders if there is a week spot (Not tighten intake down right) Remeber this statment!!!! alot off loose gasket on the intake make it look like a headgasket. Nissan or Zcardepot has a Japan made head gasket Felpros ok on L16s Edited March 17, 2021 by banzai510(hainz) 1 Quote Link to comment
