KingSlab82 Posted March 4, 2021 Report Share Posted March 4, 2021 In the works of lowering my 82 king cab 720 2WD and wondering if anyone knows if there’s someone who makes adjustable struts/shocks (not looking for air bags either) so far no luck 1 Quote Link to comment
Charlie69 Posted March 5, 2021 Report Share Posted March 5, 2021 This information applies to a 2wd truck. The front is usually done by re-indexing the torsion bars. If you change to 84 to 86 vented rotor front disc brakes you can get 2" drop spindles from Belltech and other manufactures. The rear is done by using 4x4 rear leaf springs which will drop the back of you truck approximately 1.5" to 2". I have a 1980 720 2wd reg cab and short bed chassis under my 66 520 pickup. I have Belltech 2" drop spindles on the front and 4x4 springs in the rear. The rear is not low enough for me so when I get the exhaust done on the truck I will take it to th spring shop and have 2 new leaves per side made to the height I want. This will be about $300 dollars but in doing this I get the height I want and still have 1/2 ton springs under the back of my truck so I will still be able to carry a load. Many people use lowering blocks on the rear but I will not use them. The reason why is you can not adjust the drum brakes with the lowering blocks installed. 1 Quote Link to comment
KingSlab82 Posted March 8, 2021 Author Report Share Posted March 8, 2021 On 3/4/2021 at 7:07 PM, Charlie69 said: This information applies to a 2wd truck. The front is usually done by re-indexing the torsion bars. If you change to 84 to 86 vented rotor front disc brakes you can get 2" drop spindles from Belltech and other manufactures. The rear is done by using 4x4 rear leaf springs which will drop the back of you truck approximately 1.5" to 2". I have a 1980 720 2wd reg cab and short bed chassis under my 66 520 pickup. I have Belltech 2" drop spindles on the front and 4x4 springs in the rear. The rear is not low enough for me so when I get the exhaust done on the truck I will take it to th spring shop and have 2 new leaves per side made to the height I want. This will be about $300 dollars but in doing this I get the height I want and still have 1/2 ton springs under the back of my truck so I will still be able to carry a load. Many people use lowering blocks on the rear but I will not use them. The reason why is you can not adjust the drum brakes with the lowering blocks installed. ohhh okay I see yeah i was just going to crank the torsion bars and then use 2in block in the rear. should I not do that then? I ran into a guy in town with an 80 single cab and thats what he did and it sits pretty level. 1 Quote Link to comment
Charlie69 Posted March 8, 2021 Report Share Posted March 8, 2021 (edited) If you just "crank the torsion bars that releases the tension (torque) on them and your ride is mushy, plus you are supporting the weight of the front end on your shocks. If you re-index the torsion bars then you still have the weight bearing and ride of the torsion bars. Blocks are a cheap way to lower if you do not care about keeping your rear drum brakes adjusted. When you get your truck lowered you will need to have the front end aligned. Edited March 8, 2021 by Charlie69 1 Quote Link to comment
bottomwatcher Posted March 8, 2021 Report Share Posted March 8, 2021 (edited) As Charlie said the belltech is the way to go. You will not be fucking your front ends geometry up. Crank torsion bars=reduce bumpstop clearence=ride like shit! Edited March 8, 2021 by bottomwatcher Misspelling 2 Quote Link to comment
ShutterMeShort Posted March 15, 2021 Report Share Posted March 15, 2021 Belltech drop spindles for the front is the best way to go for sure. Re-indexing the torsion bars is a decent second option but does mess with your geometry. I did blocks in the rear but the 4x4 springs are a bit better way to go but as mentioned, not super low. 1 Quote Link to comment
Charlie69 Posted March 15, 2021 Report Share Posted March 15, 2021 If you re-index 1 spline on your torsion bars yo will achieve about 1 to 1.5 inches in drop depending on the wear of the torsion bars. I am running Belltech 2" drop spindles and 1 spline re-index on my 80 720 chassis under my 66 520 for about 3" drop. Remember any time you mess with the geometry of your vehicle get an alignment done and tell the alignment tech that the vehicle has been lowered. Quote Link to comment
