blackbomber 25 Posted February 25 Report Share Posted February 25 Hey guys. well its been a while. still have the bomber. i bought new in 1984. passed emissions again with flying colors. My door is about to fall off, but thats another issue. So after work i noticed no lights on the dash. So ipulled over and got out. So no parking lights or tail lights. Blinkers ok ,brake light ok. head lights ok. i must be getting old because i cant remember if tail lights are supposed to come on aotomatically. ?? Or they come on with the first click on the control knob. so i think everything that is out is on that first switch in the control arm right?? I dont have the fuse box cover so I dont know which fuse to check. Can u guys tell me which fuse??? I think i looked at new control knob for lights a few years ago. found one for like 300 bucks. I shot some Wd 40 in the steering column area. 1 Quote Link to post
datzenmike 39,397 Posted February 25 Report Share Posted February 25 Dash, front and rear side marker, front parking and rear running lights and the license light are all on the first and second click of the headlight switch. Third fuse from the far right side of the fuse box, or the number 13 fuse. 1 Quote Link to post
yenpit 390 Posted February 25 Report Share Posted February 25 I'm in Arvada with a 1980 720 2WD parts truck! Come pick anything you want ie door hinges etc. Both doors are pretty rusty, but they are there! I'm mostly a 510 guy, so don't know WHAT parts interchange with your 1984................ PM me if interested! TJ 1 Quote Link to post
blackbomber 25 Posted February 26 Author Report Share Posted February 26 hey mike.. yea it was the fuse. not sure why. it blew. I know i have another one some where>>>>.........I will get one in tomorrow. Let you know if it blows again. thanks ps. there is just one long nut to loosen to adjust the toe in on the front wheels right?? 1 Quote Link to post
datzenmike 39,397 Posted February 26 Report Share Posted February 26 The 4x4 has two lock nuts with a long nut between that does the adjusting. You can adjust only one side but actually it should be split between the L&R tie rod ends. Don't forget to tighten the locking nuts! 1 Quote Link to post
