Tom1200 Posted February 16, 2021 Report Share Posted February 16, 2021 I have found an off the shelf throttle cable for those of us using Keihin carbs. Motion Pro part number 04-0231 It requires an adapter to be made for the fire wall. You'll need a 25-28mm long adapted one end for 14mm 1.50 thread and the other end 14mm 1.25 thread. After that you need to use a dremel to shape the gas pedal slightly to accommodate the cable end on the Motion Pro cable. Prior to this I was having custom cables made. 2 Quote Link to comment
