Converting rear straight axle to independent rear suspension
  • Replies 27
IRS will ride nice if bone stock but when pushed, suspension travel causes camber and toe changes that will steer the car from the back. By the time you stiffen the springs and shocks, lower it and sort out the insane positive camber wear on the tires you may as well have kept the solid axle. Is it really worth the bother?
  • Thanks 1
