Rusty Dawg 113 Posted February 12 Report Share Posted February 12 Howdy all, I am in the process of getting my engine running again, but before I do so I did a compression test on my cold engine and my readings after only 4 turns were the following: Cylinder 1 - 110 Cylinder 2 - 110 Cylinder 3 - 108 Cylinder 4 - 127 Is it worth continuing to get her started or should I look to fix what seems to be low readings? (rebuild?) The information I have is that compressions should be a minimum of 128psi with a deviation of 10-15% from the lowest reading to the highest. Warm regards 1 Quote Link to post
datzenmike 39,201 Posted February 12 Report Share Posted February 12 Only one is close to the minimum. Try a couple of spoonfuls of engine oil in the spark plug hole. If the rings are bad this will seal them and the compression will jump meaningfully higher. If not much change it could be the valves and seats are pitted. Lapping the valves is cheaper than rebuilding the block which won't really do much. If you have a compressor you could borrow a leak down tester. This pressurizes the combustion chamber with compressed air. If the rings are bad air will blow out the breather cap on the valve cover. If an intake valve is leaking there will be a hissing sound from the carburetor throat. If an exhaust valve is leaking you will hear it through the exhaust pipe. It might be a combination of all three. 1 Quote Link to post
Ooph! 381 Posted February 12 Report Share Posted February 12 Was the throttle wide open when you did the test? How long has it been since it last ran? 1 Quote Link to post
bananahamuck 15,126 Posted February 12 Report Share Posted February 12 If motor has been sitting forever , I would get it running best you can .. Run up to temp a few times .. then test Why start by rebuilding ? Maybe it will run just fine even with crappy/uneven compression,, you never know. j13 don’t have very good comprehension on a good day but should be somewhat even . 2 Quote Link to post
datzenmike 39,201 Posted February 12 Report Share Posted February 12 If comprehension is low but even and if not blowing a blue cloud.... drive it. Compression will probably rise slightly with some use. My old L16 in my 521 was around 120 and it used oil but not a cloud of it. It ran just fine. Later I honed the cylinders and put new rings and bearings in it. 2 Quote Link to post
320 Newb 913 Posted February 12 Report Share Posted February 12 As someone who just replaced head gasket I agree, drive it and watch for symptoms. And maybe check your compression periodically. The first symptom with my blown head gasket was exhaust blowing coolant out the radiator overflow. 1 Quote Link to post
Rusty Dawg 113 Posted February 12 Author Report Share Posted February 12 The throttle was not wide open when I ran the test. I disconnected the coil wire and turned it over 4 revolutions per cylinder. I have spark at the spark plug, so once I place some engine oil in each cylinder I will try to get her going. A local import mechanic told me to do the same thing and pour a little oil in each cylinder and try to start it. Also, he told me that I should've have done closer to 10 revolutions per cylinder for my test. Since it's been over 8 years since it ran, he said that I might be just fine once I run it a while🤞 1 Quote Link to post
datzenmike 39,201 Posted February 12 Report Share Posted February 12 I've done this with and without the throttle open and saw almost no difference. Yes running it will oil the rings and polish the valve and valve seat. It's never going to be new but it might go up some. 1 Quote Link to post
difrangia 1,698 Posted February 13 Report Share Posted February 13 If you just break it down and rebuild it, you'll always wonder how it would have resurrected if you don't give it a shot. When I acquired our 320, I knew the E1 was loosy-goosy, but I babied it around for eleven months getting acquainted while I gathered all the goodies for a rebuild. Were it mine, I'd see what it has to say and if nothing throws up a flag visually or audibly, I'd run it around at least a little. If it dumps oil out the front, back or tailpipe or rattles and bangs like two skeletons screwing on a tin roof barn, go for the rebuild. An oil pressure gage, even rigged up temporarily would help get a better read on condition. 2 1 Quote Link to post
320 Newb 913 Posted February 13 Report Share Posted February 13 3 hours ago, Rusty Dawg said: The throttle was not wide open when I ran the test. I disconnected the coil wire and turned it over 4 revolutions per cylinder. I have spark at the spark plug, so once I place some engine oil in each cylinder I will try to get her going. A local import mechanic told me to do the same thing and pour a little oil in each cylinder and try to start it. Also, he told me that I should've have done closer to 10 revolutions per cylinder for my test. Since it's been over 8 years since it ran, he said that I might be just fine once I run it a while🤞 I just pressure tested my J15 and you def need more than 4 revolutions. I put the gauge on the rocker cover so I could see when the needle stopped moving. Also do it with the throttle open just to see--it may or may not help but worth a try. My J15 with a new head gasket registered from 151-158 psi. 2 Quote Link to post
Rusty Dawg 113 Posted February 14 Author Report Share Posted February 14 Good evening, I am right on the cusp of starting this engine, but I need to know how to get it in neutral. It wants to crank over, but it's in gear. I have the rear brakes off right now with the back end on jack stands, so I can't just roll it to see if in neutral. I have my slave cylinder off since I am in the process of replacing it.....the clutch pedal went to the floor. Anyhow, can someone please direct me on the transmission sequence to find neutral? My wife asked me today what I wanted for Valentine's and I told her that I just wanted for my truck to run. Anything beyond that would be icing on the cake. I'm must be getting old😂 1 Quote Link to post
datzenmike 39,201 Posted February 14 Report Share Posted February 14 After you select what you think is neutral try to turn the driveshaft by hand if it won't turn, try again till you can spin it. It will only spin in the neutral position. 3 Quote Link to post
Rusty Dawg 113 Posted February 14 Author Report Share Posted February 14 She's alive!!! After finally getting fuel to the carburetor thru the new fuel lines she seems to run pretty nice. Seems as though I have some wires crossed since the tank is almost full but shows empty and the temp gauge started above 212 and moved downwards. Interesting that I was able to find "neutral" per datzenmike's suggestion, but when I got her started the drive line spun. Oil gauge, if working properly, showed 60psi at idle. I will try to insert a short video of her running on another posting. 3 Quote Link to post
Rusty Dawg 113 Posted February 14 Author Report Share Posted February 14 (edited) Hopefully this short video posts. Wife told me "Happy Valentine's". Might be sleeping with my Datsun tonight😄 48079857-CE0E-461C-A571-C5ABEE20954C.mov Edited February 14 by Rusty Dawg 2 Quote Link to post
datzenmike 39,201 Posted February 14 Report Share Posted February 14 Is this a positive ground?????? If accurate 60 PSI oil is very good. Does tail pipe smoke? Does it puff on restart after sitting 20 minutes?? Driveshaft will spin from oil friction. Moving parts move oil that transfers motion to non moving parts. Like an electric fan blowing on another fan and spinning it. 1 Quote Link to post
Rusty Dawg 113 Posted February 14 Author Report Share Posted February 14 Electrical stuff is not my strong suit, so I am not certain. Other than changing bulbs, I did not do any type of wiring on this truck since acquiring it last March. How do I confirm whether it's positive ground? 1 Quote Link to post
Ooph! 381 Posted February 14 Report Share Posted February 14 I believe they were originally positive ground. Here is a good thread to get started with, you want to be sure if it was changed to negative that it was done properly. Does it have an alternator or generator, radio and antenna ? https://ratsun.net/topic/28537-12v-pos-ground-to-12v-neg-ground/ 1 Quote Link to post
datzenmike 39,201 Posted February 14 Report Share Posted February 14 Looks like generator. I mentioned the ground because the gauges seem to be backwards in their readings. 1 Quote Link to post
320 Newb 913 Posted February 14 Report Share Posted February 14 Love it love it! Nice work getting it fired up it sounds good! Your temp gauge might actually be correct, on 320s the gauge rests in the off position buried all the up in the H. Then when you turn the key it drops down. Also if you've got a working thermostat you'll see the needle rise then fall when the thermostat opens. Nice work can't wait to see it on the road. 1 Quote Link to post
nicklp 17 Posted February 14 Report Share Posted February 14 Congratulations on getting it running; Hell Yes!! And a picture of the backwards assed shift pattern: 2 Quote Link to post
datzenmike 39,201 Posted February 14 Report Share Posted February 14 A gauge that reads full hot when off proves that it is working when it drops on start up. I like. 1 Quote Link to post
Rusty Dawg 113 Posted February 15 Author Report Share Posted February 15 (edited) Seems backwards, but ok. I'll go with the temp starting higher and dropping down if it wasn't for the fact that the fuel gauge shows empty. Why is this? The truck has a generator in it and an antenna, but no radio although I believe one was mounted under the dash. The truck initially smoked due to adding oil thru the spark plugs, but it has mostly gone away. I only ran it for 3-4 minutes since I wasn't sure how to deal with the temp gauge. I like the shift pattern written on the dash. It would come in handy for me for sure. Edited February 15 by Rusty Dawg 1 Quote Link to post
Ooph! 381 Posted February 15 Report Share Posted February 15 (edited) The generator will need to be polarized for negative ground if it hasn't been done. If its charging it was probably done. One side of the antenna is a direct connection to the body if the battery is reversed it may be a short unless the radio has a polarity switch, no radio no problem. I had seen a thread somewhere that was about changing earlier Datsuns but cant find it, a good search may bring it up. For British cars but there is a video on how to polarize the generator https://mossmotors.smartsupportapp.com/articles/82-Converting-to-Negative-Ground Edited February 15 by Ooph! 1 1 Quote Link to post
320 Newb 913 Posted February 15 Report Share Posted February 15 14 hours ago, Rusty Dawg said: Seems backwards, but ok. I'll go with the temp starting higher and dropping down if it wasn't for the fact that the fuel gauge shows empty. Why is this? The truck has a generator in it and an antenna, but no radio although I believe one was mounted under the dash. The truck initially smoked due to adding oil thru the spark plugs, but it has mostly gone away. I only ran it for 3-4 minutes since I wasn't sure how to deal with the temp gauge. I like the shift pattern written on the dash. It would come in handy for me for sure. It is strange how the gauges work I don't understand either. Fuel rests in the off position at empty and goes up when keyed on. Temp rests at the top in H and drops when keyed on. Maybe it's safer having baseline worst case scenario rather than a gauge breaking and thinking you have a full tank of gas and your car is always running cool? Quote Link to post
datzenmike 39,201 Posted February 15 Report Share Posted February 15 Running out of gas is easily fixed. A temp gauge that starts at cold (and may be broken) doesn't read and you may over heat before you figure it out.. 2 Quote Link to post
