Seat belt options?
chicosauce
Hi everyone,
I just picked up a 1969 521 recently. I will be posting some photos later today. I was curious what seat belt mods everyone has done. My truck currently has only lap belts and no hole along the back pillar for a shoulder belt. Before I start chopping and making holes I was wondering what everyone else has done? Should I look into aftermarket options or just go to the wreckers and pull some out of another car? Is there anything I should consider for mounting in terms of harware?
Is anyone familiar with the mike klotz write up? I cant seem to find it. If I am able to get something working Ill definitely post a write up with pics. Thanks and always appreciate any advice!
  • Replies 8
I thought the earlier 521 had what looks a spot for the 3rd point but it just didnt  have the hole and nut in it.... I have a 72 and it already had the 3rd point so I lucked out.... I think it was the first year.
I  just used a universal 3 point with the retractors.... I think I went through seatbelts planet.... there are other places too depending on the style you want.....
And there are ways to add the 3rd point I usually see a plate getting slipped inside the b piller.... I'm sure there are other ways too.....
Edited by Crashtd420
You can see if there is a "boss" or a hole like crashtd420 stated, or just weld a captive nut/plate in.  My 1972 521 has a captive nut up there.  The 510 Sedan's have a captive nut up there at the headliner, but they are too high up, especially for a shorter stature person like me!  We have lowered that captive nut & welded in place.  There was a 510 guy here or on the510realm, that bought a "plate" with a captive nut from one of the seatbelt suppliers, lowered it down the B pillar on a string to the hole, captured the plate with the bolt, & riveted it in place.  Then remove the bolt & install the buckle/loop.  Being a "plate" behind the sheetmetal gives much more rigid mounting , which truly is necessary if involved in an accident!
Personally I think old used belts are a waste, cuz so many are grungy & full of dirt/dust, don't operate correctly!  Go to seatbeltplanet or another company that sells universal fit belts.  My guess is you will want a FLOOR MOUNT retractor, where the belt pulls UP out of the unit, loops thru a buckle up the B pillar where you decide to mount it, then back down to triangulate across your chest & lap (just like any current car!) to the latch mechanism in the middle of the seat.
Hope that helps guide!
  • Like 3
Wow thanks for the advice and links everyone. Definitely feel better tackling this mini project now. I don't have the pre made holes (see photo 1) but think I can make it work. Here are some photos of my pillar and original belts. Wish I could keep them just because they are original but I have my mind set on upgrading them. Thanks again!
