Drummerboy4as Posted January 31, 2021 Report Share Posted January 31, 2021 (edited) Does anyone have a source for door hinges? I bought these on eBay several years ago, got to fitting them today and they’re incorrect. I don’t mind buying again off eBay but it would be nice if someone has actually fitted the ones they bought and can vouch that they fit. https://imgur.com/a/o3Qavw8 edit: can’t figure out how the hell to embed the images from my phone 🤷🏻♂️ Edited January 31, 2021 by Drummerboy4as Quote Link to comment
datzenmike Posted January 31, 2021 Report Share Posted January 31, 2021 See if you can swap the pin and the bushing....those are the only wear points. Hell I drilled and shortened a bolt with a nut on the end on my 620. It won't last forever but it'll work for a long time... and longer if you lube it once a year or more. What owner does that? The same ones complaining about the wear.. Quote Link to comment
Drummerboy4as Posted January 31, 2021 Author Report Share Posted January 31, 2021 The pins are fine, mostly. The hinge itself is split. I could just weld it if need be. https://imgur.com/a/eQykxHk Quote Link to comment
datzenmike Posted January 31, 2021 Report Share Posted January 31, 2021 Door swung open too far in the wind and twanged the hinge. Yeah, weld. Quote Link to comment
5t341tH Posted January 31, 2021 Report Share Posted January 31, 2021 I bought those way back then as well. It didn't fit well so I just left the original ones in place Quote Link to comment
