Lozer Posted March 3, 2021 Author Report Share Posted March 3, 2021 (edited) So no dice on running new grounds, but i was up testing different maf setups till 2 am Saturday and found a couple oddities. When I disconnect the Cts it doesn't go into limp mode. And still has a reading at the ecu..... so i ordered a new/used harness for a s13 it has the same pinout as my ecu and most of the connectors are the same. Now waiting..... Edited March 3, 2021 by Lozer Spelling Quote Link to comment
Lozer Posted March 12, 2021 Author Report Share Posted March 12, 2021 2 steps forward and a slip on my ass backward. So new harness got here and i ended up using it for diagnostics and found i was causing my self a ground loop problem. Regrounded the new ecu to the same point at the engine block and it seems to be running right for now.... Found the clutch had drained itself on my floor. Pulled the leaking slave and i found a chunk of clutch material sticking out the clutch arm hole. Thought it was chucks of an animal at first. Ordered an exedy stage 1 clutch as the fj20et seems to use the same 240mm clutct as all the other turbo motors. Quote Link to comment
Lozer Posted March 27, 2021 Author Report Share Posted March 27, 2021 (edited) So ive replaced the entire harness with a tested new (to me) harness and the random limp mode issue remains. Ive sent the ecu back to JWT with the hopes they find something wrong with it. If they can't identify the problem im going to fet a refund and buy a Haltech and have it dyno tuned. Also stay away from innovate motorsports widebands. I got a scg-1 wideband / boost controller and this pos has gone through 4 sensors in 6 months and less then 1k miles. Currently frustrated. Edited March 27, 2021 by Lozer 1 Quote Link to comment
bilzbobaggins Posted March 27, 2021 Report Share Posted March 27, 2021 Keep at it man. I like the looks of it. There is a r31 wagon over in Alabama I am trying to convince myself to buy........ 1 Quote Link to comment
Lozer Posted March 27, 2021 Author Report Share Posted March 27, 2021 Do it. They are basically just 280zx cars. My issue is all rarity of engine bits. Quote Link to comment
Lozer Posted April 3, 2021 Author Report Share Posted April 3, 2021 The endless maintenance continues.... So while waiting for my newish ecu to show up I decided to address the clutch issue. Drained the tranny and found what looks to be most of a bearing cage on the magnet. Got the trans out and found the clutch looking like this, Jesus i'm lucky it didn't just implode. To add insult to injury the front of the r200 is leaking behind the bolt. So gonna pull that too and rebuild it (needs clutches anyhow) Looking for a 240sx or sr20 or rb 5 speed as a replacement. 1 Quote Link to comment
Lozer Posted April 5, 2021 Author Report Share Posted April 5, 2021 So the front idler bearing shit itself. Its the 56mm version. I had a hell of a time finding it lots of the larger version but not many of this size. So i also found a 71c put of an rb20 with a roached 2nd gear, im hoping i can just fix up the 71c and stab that and have a new single piece shaft made. 1 Quote Link to comment
slowlearner Posted April 7, 2021 Report Share Posted April 7, 2021 Stew Wilkins was telling me that's the only thing that goes wrong with the 71C trans. The gears are super tough apparently. 1 Quote Link to comment
Lozer Posted April 15, 2021 Author Report Share Posted April 15, 2021 Happy, sad updates. Sad first. I picked up an rb20 5 speed with a "2nd gear grind" got it home popped the case and found this. 2nd gear is just toast. The rest aren't great either. So I replaced the countershaft bearing in my 71b cleaned her up and resealed her. The 71c will be getting a rebuild and a new 2nd gear when I find it. I also found out the u joints in the 2 piece driveshaft are notchy and pinned in so replacing them is either a shit show or no go. Good stuff. I got the 71b and the new exedy clutch back in the car with new seals and a DIY short shifter mod to the stock shifter/ rabbit ears. Finally got to take her out for clutch break in and deal with the cursed random limp mode........ Reverse doesn't grind almost at all any more and the notch shifter is a much improved feel. I've been working with Clark and Ben at Jim Wolf to get this stanza ecu working correctly on the fj20 and for the most part it works with the exception of randomly going into limp mode when decelerating. Clark had me ground out the TPS and disconnect the throttle switch and bang limp mode was gone. So I started playing with the voltage and found the TPS would drop down past .45v to .42 when I dropped the throttle hard so I bumped the TPS up to .5 and it would still drop down to .45 but I was still getting the limp mode issue. I then swapped out the TPS to another spare and it also would drop down past the initial voltage but I the limp mode became less consistent. I had 1 more TPS floating on my old ka24/e/de I grabbed that and popped it on and it seems the issue is gone. FFS 2 bad TPS sensors in a row. For my next act I'm going to pull the entire rear subframe and clean/ fix the lsd. 2 Quote Link to comment
Lozer Posted April 16, 2021 Author Report Share Posted April 16, 2021 She lives..... Took her out for an extended cruise tonight dialed in the ole S-AFC for optimal AFR ( small adjustments) finished up rewraping all the damn wires and harness, got the Consult back up and ready to data log. Finally a good day with her. I've renamed her Oni Chan I've gotta throw some heat reflective tape on the underside of the hood and wrap the turbo pipes. 2 Quote Link to comment
Lozer Posted April 19, 2021 Author Report Share Posted April 19, 2021 Took her out for a nice coastal Cruise today. She stayed stable the whole trip, was kinda awesome. The short throw trick with moving the swivel holes up higher worked beautifully good notch shifter engagement. Although I did notice what sounds like either the diff or the driveline making a growling noise off throttle coasting along. I replaced the rubber doughnuts between the trans mount and the chassis with poly doughnuts it may just be the trans howling through the chassis or the driveshafts notch ass u joints bitching. Either way pulling the rear subframe and getting a 1 piece axle done up. 2 Quote Link to comment
Z23T Posted April 19, 2021 Report Share Posted April 19, 2021 Lovin your car. Glad you are getting it sorted out. 1 Quote Link to comment
Lozer Posted April 26, 2021 Author Report Share Posted April 26, 2021 (edited) Thanks Z32T. So I got her together enough to take her to the historics at Sonoma. Event was kinda sad due to covid, non event people were not allowed so there were no vendors with swag or cool displays. I was the only Japanese car there so it was lonely but I got to chat about the skyline to a bunch of folks. Now the real kicker was doing the parade lap... so 2 laps around the track at 5 mph, well that shit don't fly for me so at turn 8 there was a large gap between myself and the charger in front of me.... so like any red blooded kamikaze pilot i dumped 2nd gear and drifted the shit out of it and it was all good until i went to correct it and over corrected. Needless to say i ended up in the grass on turn 8 getting laughed at by my kid. We took off after the parade lap and drove back up to Mendocino up highway 1. I'm running 450lbs springs up front and 350lbs in back. I'm shaving 100lbs of spring off each corner as that shits way to stiff. Edited April 27, 2021 by Lozer 1 Quote Link to comment
Racer X 69 Posted April 26, 2021 Report Share Posted April 26, 2021 1 hour ago, Lozer said: Thanks Z32T. So I got her together enough to take to the historics at Sonoma. Event was kinda sad due to covid, non event people were not allowed so there were no vendors with swag or cool displays. I was the only japanese car there so it was lonly but i got to chat about the skyline to a bunch of folks. Now the real kicker was doing the parade lap... so 2 laps around the track at 5 mph, well that shit dont fly for me so at turn 8 there was a large gap between myself and the charger in front of me.... so like any red blooded kamikaze pilot i dumped 2nd gear and drifted the shit out of it and it was all good until i went to correct it and over corrected. Needless to say i ended up in the grass on turn 8 getting laughed at by my kid. We took off after the parde lap and drove back up to mendocino up highway 1. im running 450lbs springs up front and 350lbs in back. Im shaving 100lbs of spring off each corner as that shits way to stiff. Any other right hand drive cars there? Quote Link to comment
Lozer Posted April 27, 2021 Author Report Share Posted April 27, 2021 None that I remember but the one car I was tripping out on was a meld up of a 69ish mustang and a 69 Lincoln continental. Front half was a mustang and from the doors back was a Lincoln. There were a couple 308 Ferrari's a shit load of mustangs, vetts and 2020 challengers... Oh there was a Suzuki Samurai so I was not the only j tin there. 1 Quote Link to comment
Lozer Posted May 3, 2021 Author Report Share Posted May 3, 2021 Spent some time getting ride height and alignment sorted damn right side was almost an inch higher, I usally sort that when I install coilovers but i must have just thrown em on. Also it would seem my oil seepage has stopped. After the ride down to infineon the car lost a .5 quart of oil and I was a little concerned. But after topping it up and running down to Golden week kyusha fest in Richmond she dident burn or leak any. Kyusha fest was cool. I saw the other dr30 that i know of in california and had a great drive. Unfortunatly my damned go pro only saved half the pictures i took...... Next thing is rebuilding the siezed ac pump and getting that working. Quote Link to comment
Lozer Posted May 6, 2021 Author Report Share Posted May 6, 2021 After driving back up to Mendocino last Saturday the weather was in the 90's and hommie don't play that. Part of why I sold my 510 was the lack of creature comforts and just how damn uncomfortable the car was (my fault for building it that way). The skyline came with a locked up ac compressor and I figured like everything else on the car it died from lack of use. So I stripped it down and found that the blades had locked up in the turbine from gummed up oil and a touch of surface rust. A hard hit of 1000 grit later she spins freely and the clutch works. Now to convert to the crappy R134 and have slightly colder then 90* air blowing in my face. 3 Quote Link to comment
Lozer Posted May 14, 2021 Author Report Share Posted May 14, 2021 So this pretty thing showed up from import drag works. Took some work to get it in but its a perfect fit. Also replaced my front seal on the r200. Hope I didn't fuck up the pinion depth. Also had to solder on the radiator overflow nipple as it was slowly leaking. 3 Quote Link to comment
Lozer Posted May 15, 2021 Author Report Share Posted May 15, 2021 So got sick of the back seat looking like it had been set on fire then shit on. So i did a seat delete. Quote Link to comment
Lozer Posted May 15, 2021 Author Report Share Posted May 15, 2021 Gonna cover it with vinyl and wrap the inner fenders. Quote Link to comment
Lozer Posted May 16, 2021 Author Report Share Posted May 16, 2021 So with or without body kit. Im completly on the fence. Quote Link to comment
bilzbobaggins Posted May 16, 2021 Report Share Posted May 16, 2021 Both do look good. Gotta ask, would it look silly with the chin and no side skirts? 1 Quote Link to comment
Z23T Posted May 16, 2021 Report Share Posted May 16, 2021 The skirts and chin spoiler have an old school cool look, but I think the car looks better/cleaner without them. 1 Quote Link to comment
Racer X 69 Posted May 16, 2021 Report Share Posted May 16, 2021 (edited) Skirts and airdam, replace the OEM crash bumpers with lightweight composite that blends the airdam with the front end and smooths the body lines in the rear. Oh, and nice business coupe rear seat delete. Edited May 16, 2021 by Racer X 69 1 Quote Link to comment
thisismatt Posted May 16, 2021 Report Share Posted May 16, 2021 I wasn't really paying attention to the dates, but it seemed like you make great progress 👍 I like the kit, unless you plan to lower it. It gives it a look like it's lower, making it look less like an 80s/90s sedan. 1 Quote Link to comment
