Juan Ochoa Posted January 7, 2021 Report Share Posted January 7, 2021 So I started working on my 85 720 4x4 and so far it has been easy. I have another 720 I wanted to take the engine out of and use for the 4x4. Here’s the problem, the 720 I’m pulling the engine from is a 2wd model. And from what I learned so far the engine from the 2wd one isn’t going to fit in the 4x4 because the oil pans are different. I was wondering if anybody knows where I can find a pan for the 4x4 because I’ve looked everywhere online and in junkyards and found nothing. 1 Quote Link to comment
datzenmike Posted January 7, 2021 Report Share Posted January 7, 2021 I guess you don't have an engine in the 4x4? 1 Quote Link to comment
Juan Ochoa Posted January 7, 2021 Author Report Share Posted January 7, 2021 Just now, datzenmike said: I guess you don't have an engine in the 4x4? Nope, not yet 1 Quote Link to comment
datzenmike Posted January 7, 2021 Report Share Posted January 7, 2021 '83 and up Z24 4x4 will work for sure. The '81-'82 pan will fit the engine and... should fit the truck. 1 Quote Link to comment
Juan Ochoa Posted January 7, 2021 Author Report Share Posted January 7, 2021 1 minute ago, datzenmike said: '83 and up Z24 4x4 will work for sure. The '81-'82 pan will fit the engine and... should fit the truck. Do you know where I can find these pans? 1 Quote Link to comment
Lockleaf Posted January 7, 2021 Report Share Posted January 7, 2021 Post want ads here and Facebook and Craigslist. Try car-parts.com. buy a beater parts truck. Buy a welder, cut out the offending section, weld on some extra volume to the passenger side. That's basically what Nissan did. 1 Quote Link to comment
weldingrod Posted January 7, 2021 Report Share Posted January 7, 2021 Put the smaller 2wd into a 4x4, basically dropped in. Had to change the oil pan and oil pickup from the pooched 4x4 engine, everything fit. Also put in the bigger 4x4 clutch pack. When I changed oil pans I could see where the 2wd oil sump had been cut off and the 4x4 one welded on. Just something a welder would notice. My theory is the Japanese thought the 4x4 thing was just a fad but when it became a thing they converted the oil pans they had in stock to put out 4x4's until they had the tooling to make 4x4 oil pans. Quote Link to comment
datzenmike Posted January 7, 2021 Report Share Posted January 7, 2021 The L20B 4x4 oil pan is different than all the Z series pans. Can anyone say what the difference is?? Quote Link to comment
bilzbobaggins Posted January 7, 2021 Report Share Posted January 7, 2021 Different because of the clocking of the motor? Quote Link to comment
datzenmike Posted January 8, 2021 Report Share Posted January 8, 2021 I'll give you that.. but this is specific to the oil pan itself, not really the engine it's on. Quote Link to comment
bilzbobaggins Posted January 8, 2021 Report Share Posted January 8, 2021 I couldnt wait so I looked it up. I was right the second time, but not for the exact right reason. lol Quote Link to comment
SLO720 Posted January 8, 2021 Report Share Posted January 8, 2021 If you were closer I have a couple pans and pickup tubes for the later model 4x4. In located in Va. 1 Quote Link to comment
datzenmike Posted January 8, 2021 Report Share Posted January 8, 2021 Pictured was a one year only 720 4x4 oil pan that would fit the L series engine. That year only, the differential was on the right side with the oil pan drooping down on the left or driver's side. All other years the front differential was on the left side and the pan drooping on the right. Why? No idea. 3 Quote Link to comment
