SLO720 Posted January 1, 2021 Report Share Posted January 1, 2021 Hello all, I was wondering if the 720 l20b was ever optioned with a power steering system? Getting ready to potentially purchase an 80 720 with l20b. Truck has a factory A/C system on it. Kinda kicking myself for not harvesting the ld28 powersteering pump and brackets before I sold it (Just for the possibility of it even fitting). Will get this truck with a 85 base model truck that is power steering and the '80 is pretty rotted so may do a drivetrain swap. The z24 had a bad head gasket and has set for about 6 years. 1 Quote Link to comment
datzenmike Posted January 1, 2021 Report Share Posted January 1, 2021 No PS pump for the L20B only Z22 and up. PS boxes all look the same so that part could be put on your '80 truck, you just have to make up a pump drive for the L20B. I did make a mount up using a D21 pump with the fender mounted reservoir. It fit below the distributor where the A/C pump would normally go. 1 Quote Link to comment
