Cuts metal like mad Posted January 9, 2009 Author Report Share Posted January 9, 2009 here's an update for you guys... I've been running the carb for awhile now, taken several drives, and I am pleasently surprised at well they work. The only thing I've done thus far, is to lean them out by one notch on the fuel mixture needles... Using my wideband nostril sensor, I came to the conclusion that it was running a little rich, also my tear duct sensor releasing fluid clues me in as well... After adjusting the mixture I have taken several spirited drives and upon pulling the the plugs for reading they came out as a perfect light tan color. I posted on another forum about this setup and was given a hard time cause I won't dyno it... I don't really see the point, plugs look good, car runs and drives great, and I doubt there's much power to be made in tuning... Maybe 5hp max. The I only problem I have run into is that it feels like when I run the car from a stop through the gears at 6500rpm per shift, it's running out of fuel around 5000rpm in 4th (4spd tranny)... This was expected however cause I am running the stock fuel pump. In the article they suggest using a high volume/low pressure electric pump, I agree. I have read that people are having good results with the R1 stock electric pump... The stock L series mechanical pump is the right pressure, but not high enough volume at prolonged high rpm. A spirited drive through the canyons, or autocross would be fine, since it doesn't use as much fuel in a short "burst"... In reality, how often do you go from zero to 5000+rpm in top gear. Quote Link to comment
banzai510(hainz) Posted January 9, 2009 Report Share Posted January 9, 2009 Joe, A stock pump should be good in my opinion. I run a stock pump on my beater and those are 40mm carbs Ever take a stock pump the outlet and start the car. There is alot of gas shooting out of that hose. ALOT!!!!!!!!!!!!!!!!! 1 Quote Link to comment
RacnJsn95 Posted January 9, 2009 Report Share Posted January 9, 2009 I followed your post on the realm... I don't post much over there, seems like a lot of nit-picking if you don't have "proof"... I've read of guys using stock fuel pumps and making them boost referenced on turbo applications... I wonder if there is a way to modify a stock pump in a different way to make it work. Quote Link to comment
Cuts metal like mad Posted January 9, 2009 Author Report Share Posted January 9, 2009 (edited) overall the car runs awesome, and pulls hard. I've driven fast cars, and quick cars... The L16 is neither... But I am still quite satisfied with results, i'd love to try these on a bigger motor. The sound is nothing short of amazing! Oh... And these results are based on a motor with low compression numbers also... So I can only imagine how entertaining it would be on a healthy one. Edited January 9, 2009 by zuum510 Quote Link to comment
banzai510(hainz) Posted January 12, 2009 Report Share Posted January 12, 2009 http://ozdat.com/forum/viewtopic.php?f=28&t=15590 Quote Link to comment
agentalpha Posted January 12, 2009 Report Share Posted January 12, 2009 Your success with these carbs, and the fact they can be had so inexpensively, makes me almost want to sell off my Mikuni's, and try to adapt them to my L6... AWESOME work, Bro!:D Quote Link to comment
BACARDI_DWB Posted January 14, 2009 Report Share Posted January 14, 2009 http://www.totalvauxhall.co.uk/resources/totalvauxhall/TOV64.tech60697.pdf Very good article on the same idea. Quote Link to comment
Jester Posted March 1, 2009 Report Share Posted March 1, 2009 DAMN GOOD READING GUYS!!!!! This is a KILLER write up. Joe: Thanks for doing all the hard work of putting this together. Very appealling to me as well. :rolleyes::rolleyes::D Quote Link to comment
datzenmike Posted March 1, 2009 Report Share Posted March 1, 2009 Zuum, how is the fuel fed to the carb? If it is fed in from one end and connected in series there will be a pressure drop at each carb leaving the the carb at the far end a little short on a long enough full throttle run. Maybe longer equal length tubing from each carb to a common connection from the fuel pump.???? Quote Link to comment
Wharf Rat Posted March 1, 2009 Report Share Posted March 1, 2009 Good read, I have a set off a XS1100 they sound so nice with a set of stacks on a bike they must realy howl when you draw more volume through them with the bigger displacment engine. Thinking about this application for the six clyinder Zs maybe use two sets off the Yamaha XS850 triple. Very Cool and nice work! Quote Link to comment
Cuts metal like mad Posted March 2, 2009 Author Report Share Posted March 2, 2009 Sounds ok mike, however I think that having four fuel lines would drop off MORE than a single line that feeds all four carbs in series. Something that I have also considered is that the fuel lines may just be too small... Wharf Rat, something you may want to keep in mind is carb size, its important... :D Quote Link to comment
datzenmike Posted March 2, 2009 Report Share Posted March 2, 2009 Yes, a larger line would reduce the drop if they are in series. You could also feed fuel from both ends. After all these are bike carbs intended for half the engine size. Quote Link to comment
SHADY280 Posted March 2, 2009 Report Share Posted March 2, 2009 good to hear zumm i got my intake flanges from RacnJsn95 and they look great. thats as far as i have made it. im building my shop so everything has taken a back seat as the racecar needs to sit on its own wheels for the move to the new shop. after that the 620 can recieve some time. the positive results are very encouraging as my motor has good compression numbers and i have a flowbenched 219 sss head for the truck as well now. plus im gonna find some stacks and an aircleaner setup. Quote Link to comment
datsunfish Posted March 2, 2009 Report Share Posted March 2, 2009 This is some pretty cool stuff here. What I dont get is why some of you are worried about how to adapt a brake booster line. Simply install a port on one manifold runner and it will be fine. You dont have to worry about runability when your off the throttle and braking. If it gets stumbly then run one across all runners. Look at a weber or mikuni manifold. As for the dizzy advance cant you remove some counterweights or something? Being that you can use weber jets this may be something I would consider. Great work and way to write it up. Quote Link to comment
SHADY280 Posted March 2, 2009 Report Share Posted March 2, 2009 running it across all ports will equalize the pressure that would be stolen from one cylinder, possibly causing it to run funny. and yes twin carb setups take it from one side only, but they also have a balance tube in most setups. i just wanna cover my bases, altho it would be nice to not have to build an ugly tube across the whole thing Quote Link to comment
Wharf Rat Posted March 2, 2009 Report Share Posted March 2, 2009 I would like to add that on the later Yamahas they have a tube built into the head that joins the carbs intake, they claim it increases low end. When you sync the carbs you remove a plug at one end and install a o ringed shaft so you can sync them more accurately. On your handmade intakes it would be a good idea to have small ports with hose nipples for syncing them like on the bikes. you can use one for your dist. advance and plug the others. on the XS1100 that is what they do. I would use a exaust air injection tubes setup (smog) or build somthing like one for the brake booster vac. Peace WRAT Quote Link to comment
Cuts metal like mad Posted March 2, 2009 Author Report Share Posted March 2, 2009 A tip I learned a long time ago and seemes to have applied here; if you suspect fuel problem, check ignition. if you suspect ignition problem, check fuel. So I swapped out the nikki pump for a 'ampco' (nikki clone) pump... and exactly same problem. So I decided it HAD to be my Jacobs ignition system... swapped out the jacobs CRAP!!! for a stock points coil... and can you guess? HELL YEAH! FIXED... wtf, I hate Jacobs. It even has more off the line power... Runs PERFECT, and pulls hard in every gear now. WHEW! I love free fixes. Quote Link to comment
datto510 Posted March 2, 2009 Report Share Posted March 2, 2009 Alright Joe! Now when you gonna put a 5-speed in that beast? Quote Link to comment
banzai510(hainz) Posted March 2, 2009 Report Share Posted March 2, 2009 Joe ,Kinda goes back to the MSD6 you was going to give me. Quote Link to comment
fisch Posted March 3, 2009 Report Share Posted March 3, 2009 Sounds like it is time for a new video!!!! Run that thing through the gears for us! Quote Link to comment
Cuts metal like mad Posted March 3, 2009 Author Report Share Posted March 3, 2009 sorry fisch, unless someone local wants to volunteer to help me do it, I won't be able to. Its just too much trouble to do with my phone... you'll just have to take my word for it. Quote Link to comment
72240z Posted March 3, 2009 Report Share Posted March 3, 2009 sorry fisch, unless someone local wants to volunteer to help me do it, I won't be able to. Its just too much trouble to do with my phone... you'll just have to take my word for it. Someone should step up on that, after the trouble zuum has gone through to keep us informed the least someone could do is go for a fun ride and hold a cam. Quote Link to comment
fisch Posted March 3, 2009 Report Share Posted March 3, 2009 Agreed! I'd be over is a sec, if I wasn't on the other side of the country! This is a really cool thing you've done here Zuum. And if I haven't said it, the bike in your profile pic is a freakin work of art man. Quote Link to comment
Cuts metal like mad Posted March 3, 2009 Author Report Share Posted March 3, 2009 It was really fun to share... and more fun to put it together. Quote Link to comment
72240z Posted March 3, 2009 Report Share Posted March 3, 2009 Even more fun to drive I bet lol. Quote Link to comment
