banzai510(hainz) Posted August 23, 2021 Report Share Posted August 23, 2021 guess I got to redo my video Quote Link to comment
Richie Posted August 23, 2021 Author Report Share Posted August 23, 2021 2 hours ago, Crashtd420 said: Not if you installed it correctly.... as long as you have enough room to get your initial timing and can lock down the plate you'll be fine.... I definitely do not have enough room to bolt the distributor down. Quote Link to comment
banzai510(hainz) Posted August 23, 2021 Report Share Posted August 23, 2021 (edited) 2 minutes ago, Richie said: definitely do not have enough room to bolt the distributor down. what????????????????????????????????? photos rotate the dost pedastal 180 on the front cover so the vac adv is on the other side and then redo your plug wire. you even watch my vid in dist install? Edited August 23, 2021 by banzai510(hainz) 1 Quote Link to comment
Richie Posted August 23, 2021 Author Report Share Posted August 23, 2021 33 minutes ago, banzai510(hainz) said: what????????????????????????????????? photos rotate the dost pedastal 180 on the front cover so the vac adv is on the other side and then redo your plug wire. you even watch my vid in dist install? Yea I did watch your video. I’m currently watching it now. So the distributor vac should be turned 180 then. Quote Link to comment
