Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 2 hours ago, Crashtd420 said: I know someone else had an issue like that where the person retapped the hole for a AN fitting.... Do you have the old sender or fitting that was originally in the hole? Yea I do. It fits fine. I also bought a new one from rock auto and that fit fine. It’s weird 1 Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 I bought one more adapter and if this one doesnt fit, i am just going to run a tap through it. Quote Link to comment
Crashtd420 Posted August 19, 2021 Report Share Posted August 19, 2021 6 hours ago, Richie said: Yea I do. It fits fine. I also bought a new one from rock auto and that fit fine. It’s weird Now I'm confused what fits fine? The sender? Then why are you buying adapters? Are you trying to adapt to npt for aftermarket gauges? 2 Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 27 minutes ago, Crashtd420 said: Now I'm confused what fits fine? The sender? Then why are you buying adapters? Are you trying to adapt to npt for aftermarket gauges? Yea the aftermarket sender is 1/8 NPT 27. 1 Quote Link to comment
Crashtd420 Posted August 19, 2021 Report Share Posted August 19, 2021 50 minutes ago, Richie said: Yea the aftermarket sender is 1/8 NPT 27. And you are ordering a Male bspt to female npt right..... Do you have a set of verniers for measuring? You could compare the end diameter of the sender to the adapter... 1 Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 8 minutes ago, Crashtd420 said: And you are ordering a Male bspt to female npt right..... Do you have a set of verniers for measuring? You could compare the end diameter of the sender to the adapter... yea male Bsp to female NTP https://www.amazon.com/gp/product/B00V5Q6GME/ref=ppx_yo_dt_b_asin_image_o03_s00?ie=UTF8&psc=1 And no i do not 1 Quote Link to comment
Crashtd420 Posted August 19, 2021 Report Share Posted August 19, 2021 10 minutes ago, Richie said: yea male Bsp to female NTP https://www.amazon.com/gp/product/B00V5Q6GME/ref=ppx_yo_dt_b_asin_image_o03_s00?ie=UTF8&psc=1 And no i do not Well a couple reviews claim the same issue, they say the Male end is npt.... I hope this wasnt the newest one you bought.. 1 Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 20 minutes ago, Crashtd420 said: Well a couple reviews claim the same issue, they say the Male end is npt.... I hope this wasnt the newest one you bought.. that was one of them, but i bought one from Zcar depot same thing, and this one that i am waiting on is from oriellys Quote Link to comment
datzenmike Posted August 19, 2021 Report Share Posted August 19, 2021 BSPT are 55 degree thread angle while NTP is 6. Sometimes the NTP will seem to fit the hole but the threads will never seal. Seems very unlikely Zcar Depot would send you an NPT sender unless you asked them to. ALL Nissans are BSPT at least into the 2000s and probably are today. 1 Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 (edited) 10 minutes ago, datzenmike said: BSPT are 55 degree thread angle while NTP is 6. Sometimes the NTP will seem to fit the hole but the threads will never seal. Seems very unlikely Zcar Depot would send you an NPT sender unless you asked them to. ALL Nissans are BSPT at least into the 2000s and probably are today. https://zcardepot.com/products/adaptor-bpt-to-npt-pipe-fitting-1-8?variant=19275564089457 This is the one i got. it wont even fit the oil hole. The amazon one almost fit. Edited August 19, 2021 by Richie Quote Link to comment
Crashtd420 Posted August 19, 2021 Report Share Posted August 19, 2021 25 minutes ago, Richie said: https://zcardepot.com/products/adaptor-bpt-to-npt-pipe-fitting-1-8?variant=19275564089457 This is the one i got. it wont even fit the oil hole. The amazon one almost fit. That definately weird..... Not sure what to say other than I hope the oriellys one works.... Quote Link to comment
datzenmike Posted August 19, 2021 Report Share Posted August 19, 2021 Says... Description New 1/8" BPT to 1/8" NPT pipe fitting adaptor. BPT are similar but not the same as NPT, so this adaptor can be used when fitting more common NPT accessories to the cooling system on Datsun Z cars. Note that 1/4" pipe fitting has an actual O.D. of about 3/8". Seems to me this is not the oil pressure sender adapter but probably for the water temperature sender in the thermostat. You need BSPT thread not BPT Quote Link to comment
Richie Posted August 19, 2021 Author Report Share Posted August 19, 2021 12 minutes ago, datzenmike said: Says... Description New 1/8" BPT to 1/8" NPT pipe fitting adaptor. BPT are similar but not the same as NPT, so this adaptor can be used when fitting more common NPT accessories to the cooling system on Datsun Z cars. Note that 1/4" pipe fitting has an actual O.D. of about 3/8". Seems to me this is not the oil pressure sender adapter but probably for the water temperature sender in the thermostat. You need BSPT thread not BPT WOOOOW. I am going to jump off of something. Man from the very beginning problem after problem and all i need to do is pay attention better. I really appreciate the help. Well not i have a coolant adapter I guess. 1 Quote Link to comment
Richie Posted August 20, 2021 Author Report Share Posted August 20, 2021 2 hours ago, datzenmike said: Says... Description New 1/8" BPT to 1/8" NPT pipe fitting adaptor. BPT are similar but not the same as NPT, so this adaptor can be used when fitting more common NPT accessories to the cooling system on Datsun Z cars. Note that 1/4" pipe fitting has an actual O.D. of about 3/8". Seems to me this is not the oil pressure sender adapter but probably for the water temperature sender in the thermostat. You need BSPT thread not BPT So I just got the adapter and it reads 1/8 bsp 1 Quote Link to comment
Figbuck Posted August 20, 2021 Report Share Posted August 20, 2021 On 1/6/2021 at 4:39 PM, Figbuck said: Something that caused me issues was the Oil Pressure Sender. I wish I would have bought a new sender unit for my Auto-Meter oil pressure gauge... and made sure the threads in the block were the right ones... or else, tapped new threads before I "boiled" the block clean. The stock idiot light has a different thread pitch than most of the sending units. I know there are a ton of little things to remember and do, but this item can save you grief just as you want to get finished and fire it off! In the end I got a generic oil pressure sender from O'Reily's. Napa and Baxter's were a no go. It has two tangs, to the gauge and to ground. I would not tap the block!!! What could go wrong? Ewwwww... the thought of metal shavings and crankcase make me cringe... Quote Link to comment
datzenmike Posted August 20, 2021 Report Share Posted August 20, 2021 From it's position, any chips would be pushed up into the cam. Quote Link to comment
Stoffregen Motorsports Posted August 20, 2021 Report Share Posted August 20, 2021 https://www.pegasusautoracing.com/ sells the BSPT adapter. The T is important. https://www.pegasusautoracing.com/productselection.asp?Product=3201-001 Quote Link to comment
Richie Posted August 20, 2021 Author Report Share Posted August 20, 2021 https://imgur.com/a/oMzXkX7 O’rilley’s came through 2 Quote Link to comment
Crashtd420 Posted August 20, 2021 Report Share Posted August 20, 2021 9 minutes ago, Richie said: https://imgur.com/a/oMzXkX7 O’rilley’s came through That's good.... Quote Link to comment
Richie Posted August 21, 2021 Author Report Share Posted August 21, 2021 https://imgur.com/a/KyYt9QK It fires! Just have to set the timing. The alternator is charging correctly no leaks (so far). Thank you guys! 3 Quote Link to comment
Stoffregen Motorsports Posted August 22, 2021 Report Share Posted August 22, 2021 Good thing the alternator doesn't leak...Whew! 1 Quote Link to comment
datzenmike Posted August 22, 2021 Report Share Posted August 22, 2021 (sealed bearings, sssh) 2 Quote Link to comment
Richie Posted August 22, 2021 Author Report Share Posted August 22, 2021 When I set the timing, I have to drop the oil pump and move the distributor shaft? Quote Link to comment
Crashtd420 Posted August 22, 2021 Report Share Posted August 22, 2021 5 hours ago, Richie said: When I set the timing, I have to drop the oil pump and move the distributor shaft? Not if you installed it correctly.... as long as you have enough room to get your initial timing and can lock down the plate you'll be fine.... 1 Quote Link to comment
datzenmike Posted August 22, 2021 Report Share Posted August 22, 2021 What Crashtd said. There a bolt to loosen on the underside of the distributor that will allow you to twist it to find and set your advance. 1 Quote Link to comment
