datzenmike Posted May 18, 2021 Report Share Posted May 18, 2021 That's never a good idea. If it ran, then the cam timing is probably OK. If it's out you don't need to take it apart, there is a way to see if it's out, not guesswork, and an adjustment can be made. Same with the ignition timing, it can be checked and adjusted if needed. 1 Quote Link to comment
Richie Posted May 18, 2021 Author Report Share Posted May 18, 2021 22 minutes ago, datzenmike said: That's never a good idea. If it ran, then the cam timing is probably OK. If it's out you don't need to take it apart, there is a way to see if it's out, not guesswork, and an adjustment can be made. Same with the ignition timing, it can be checked and adjusted if needed. it wasnt running and honestly i just wanted to rebuild it and learn why not Quote Link to comment
Richie Posted May 18, 2021 Author Report Share Posted May 18, 2021 so I got the timing kit in. There is no timing indicator on the back of the sprocket and no indicator on the chain itself. https://imgur.com/a/inJUpN7 Quote Link to comment
Draker Posted May 18, 2021 Report Share Posted May 18, 2021 11 minutes ago, Richie said: so I got the timing kit in. There is no timing indicator on the back of the sprocket and no indicator on the chain itself. https://imgur.com/a/inJUpN7 Best thing you can do is pull the marks of the old set and copy them over to the new. I had this issue once.. now I just look for kits with the markings. OSK is a good one. 1 Quote Link to comment
Richie Posted May 18, 2021 Author Report Share Posted May 18, 2021 3 minutes ago, Draker said: Best thing you can do is pull the marks of the old set and copy them over to the new. I had this issue once.. now I just look for kits with the markings. OSK is a good one. Yea I counted the teeth and teeth in between the marks. It matches correctly. With the chain thoo I was thinking making the marks line up with the old chain by counting and that’ll be my new indicator on my new one. Sound correct? 1 Quote Link to comment
Draker Posted May 19, 2021 Report Share Posted May 19, 2021 6 hours ago, Richie said: Yea I counted the teeth and teeth in between the marks. It matches correctly. With the chain thoo I was thinking making the marks line up with the old chain by counting and that’ll be my new indicator on my new one. Sound correct? Yep, as long as it’s the same length. Make a mark, scratch a line into it or something. Same with the cam gear. Don’t go crazy, just enough to see if it gets oily. 1 Quote Link to comment
datzenmike Posted May 19, 2021 Report Share Posted May 19, 2021 Without the V notch cut above those 3 holes, you can't check later to see if the sprockets and chain are worn. At top dead center the notch should be below and just slightly to the right of the etched mark on the cam thrust plate behind it... 1 1 Quote Link to comment
Draker Posted May 19, 2021 Report Share Posted May 19, 2021 That is the real problem. If you transfer the marks from the old pulley to new, it’s better than nothing. You can see the mark on the back, so you might have to get creative to make it work. 1 Quote Link to comment
banzai510(hainz) Posted May 19, 2021 Report Share Posted May 19, 2021 (edited) to mark the chain ,the stock one was a jap made one youll have the brite links. just put them up to the new chain and mark them with paint or what ever. the spocket best to pick the center point of the dowel hole then ectch the mark on the upper part of the sprket and maybe where the V nocth on the trucst plate you have to make it higher to see. really in this case youll use the brite links on the chain lined up with the dimples on the sprockets that will be the best you can do. You can set to 1 or 2 on sprocket. L20 are on #2 dowel on stock set ups. L16s l18s its usually on #1 but on performance cams it could be any of the holes to get best set up. But since you cant see its almost useless to timed the cam perfect.Unless one has a degree wheels and can figure it out Edited May 19, 2021 by banzai510(hainz) 1 Quote Link to comment
Richie Posted May 21, 2021 Author Report Share Posted May 21, 2021 Hey so as I put the new gasket on I noticed 4 extra holes in the gasket on the exhaust side of the block where there isn’t any holes. Is this a problem? https://imgur.com/a/SyNuPjl Quote Link to comment
Stoffregen Motorsports Posted May 21, 2021 Report Share Posted May 21, 2021 Nope! 1 Quote Link to comment
Crashtd420 Posted May 21, 2021 Report Share Posted May 21, 2021 4 hours ago, Richie said: Hey so as I put the new gasket on I noticed 4 extra holes in the gasket on the exhaust side of the block where there isn’t any holes. Is this a problem? https://imgur.com/a/SyNuPjl I cant really tell for sure because of the angle of the picture , but make sure the fire ring of the head gasket is bigger than the bore, it looks really close.. . Quote Link to comment
Richie Posted May 21, 2021 Author Report Share Posted May 21, 2021 2 hours ago, Crashtd420 said: I cant really tell for sure because of the angle of the picture , but make sure the fire ring of the head gasket is bigger than the bore, it looks really close.. . Ooo it does look close. I see what you mean. Dang I torqued it down already Quote Link to comment
Stoffregen Motorsports Posted May 22, 2021 Report Share Posted May 22, 2021 You could see the whole piston in the pic. I'd say it's fine. 1 1 Quote Link to comment
Richie Posted May 22, 2021 Author Report Share Posted May 22, 2021 5 hours ago, Stoffregen Motorsports said: You could see the whole piston in the pic. I'd say it's fine. Yea I took it off and looked at it. The angle makes it look like it barely clears but it’s fine. Thanks for noticing that. 2 Quote Link to comment
Crashtd420 Posted May 23, 2021 Report Share Posted May 23, 2021 One reason I hate pictures, I didnt mean for you to have to take it apart, but atleast you know your good.... 1 1 Quote Link to comment
Richie Posted May 27, 2021 Author Report Share Posted May 27, 2021 https://imgur.com/a/FEOaTCq so I got the OSK timing kit from eBay and it doesn’t have the timing marks on the back but it has the numbers on the front and the sprocket looks different. Any thoughts? Quote Link to comment
datzenmike Posted May 27, 2021 Report Share Posted May 27, 2021 I would file a small notch above each hole. If the large holes don't allow you to se the notches then don't bother. When the engine is properly set to TDC the notch is the only way to check for proper cam timing or wear. 1 Quote Link to comment
banzai510(hainz) Posted May 27, 2021 Report Share Posted May 27, 2021 (edited) Crap I cant believe they have gone bad also on those timing kits no masrks on them Tsubaki is the one to get https://www.ebay.com/itm/351435735931?hash=item51d333c37b:g:-qAAAOSwo0JWO1KX least its has the brite links I would take the old sprocket and get a matching size drill bit and put them together and ink pen it then make a notch with a GOOd corner of the file to get the that v mark on the sprockets Edited May 27, 2021 by banzai510(hainz) 1 Quote Link to comment
Richie Posted May 27, 2021 Author Report Share Posted May 27, 2021 4 minutes ago, banzai510(hainz) said: Crap I cant believe they have gone bad also on those timing kits also. Tsubaki is the one to get I was pretty upset also because i contacted the seller and he verified it. But i am just going to transfer the marking. I feel like the marks on the back are pretty important and dont understand why manufacturers wouldnt recognize that. Quote Link to comment
banzai510(hainz) Posted May 27, 2021 Report Share Posted May 27, 2021 at least it has the HOLES to see thru as the Mellig and Cloyes ones the inspection hole is in the wrong spot. Just use the brite links on initial set up to get right and then use the timing marks on the crank and pointer. Hope for best on cam sprocket. but if brite linkon sprocket dimple your OK 1 Quote Link to comment
Richie Posted May 27, 2021 Author Report Share Posted May 27, 2021 1 minute ago, banzai510(hainz) said: at least it has the HOLES to see thru as the Mellig and Cloyes ones the inspection hole is in the wrong spot. Just use the brite links on initial set up to get right and then use the timing marks on the crank and pointer. Hope for best on cam sprocket. but if brite linkon sprocket dimple your OK I am currently watching that video also Quote Link to comment
Richie Posted May 28, 2021 Author Report Share Posted May 28, 2021 https://imgur.com/a/vXFRcpK this is what I got. What y’all think? Quote Link to comment
Richie Posted May 28, 2021 Author Report Share Posted May 28, 2021 https://imgur.com/a/spMs5JF please let me know if something is off. I triple checked but I wanna make sure Quote Link to comment
datzenmike Posted May 28, 2021 Report Share Posted May 28, 2021 This one needs to go to the next number up. This will move the sprocket 4 degrees clockwise, or about the width of the V. This one is good enough It's absolutely essential that the engine be at TDC and all slack removed from the tension side chain. 1 Quote Link to comment
