datzenmike Posted January 25, 2021 Report Share Posted January 25, 2021 The length may be different. They are either (predominantly) 31.5"..... or 26" long. Only the 720 used the shorty 26". The '82 could also be a 4 speed rather than a 5 speed but all '83 and up were 5 speeds. Make sure you check and get what you want. If the '84 is 31.5" long, any other 71B that is 31.5" long could be fitted by putting the front case from the '84 on it. In all there were L, Z, CA, LD and SD series transmissions and only the front case is really the difference. 1 Quote Link to comment
