Led headlight Harness Amazon/Ebay
SLO720
Hello all, recently purchased a cheap ($20) led harness and installed it. Very straight forward. Each plug is individually grounded. The only thing needed work was to rearrange the pins to the plug going to one of the outer most headlight harness plugs (to the truck harness plug). You also have to add power to the relays through a wire already included (already had a inline fuse installed). It was approximately a 15 minute install with the headlight already in the buckets.
Edited by SLO720
  • Replies 10
Yeah, this harness made it very painless. My 4x4 in the background I never got right on my own and had the high beams on a toggle switch
Edited by SLO720
https://ibb.co/84PG4vJI was planning on buying a relay harness kit as well. As looking on eBay and Amazon I found one that says “negative switch converted. I was wondering if that would work better than the regular one that you got. Let me know thanks https://www.amazon.com/dp/B07M6W1PMK/ref=cm_sw_r_cp_api_glc_fabc_TEhZFbKYZH66G?_encoding=UTF8&psc=1
This is the unit I used:
https://www.amazon.com/dp/B06XJ771YQ/ref=cm_sw_r_cp_apa_fabc_T1oZFb3RVQP9R?_encoding=UTF8&psc=1
@Buckner99 the harness I used does the exact same thing. It sources sensed power from the factory harness then switches power through the relays. Also the harness you linked is a 2 headlight setup not 4, something to also be careful of.
Edited by SLO720
Np! Just remember to switch the harness leads around in the source power plug to look like the one I posted above. After that it should be smooth sailing 🙂
Edited by SLO720
