Phatjimmy Posted December 1, 2020 Author Report Share Posted December 1, 2020 Lol. You are the King Rat👍 Quote Link to comment
Phatjimmy Posted December 2, 2020 Author Report Share Posted December 2, 2020 I'm pleased to report back that the Napa Echlin LS6501 twist socket is the correct one for our Datsun's instrument cluster lights. Below are the pictures for your viewing pleasure. So to anyone struggling getting you cluster lights working, worry no more. The only downside here is I love Napa but they are expensive in general. My local store charged me $4.59 each (I only bought 3). But beggars can be choosers. I wish superbright had the 5/8" sockets but they don't, just the smaller one. I hope this helps. Quote Link to comment
Phatjimmy Posted December 2, 2020 Author Report Share Posted December 2, 2020 Well I broke another socket trying to clean the contacts and realized that I am being cheap and trying to reuse 45 year old Japanese plastic. So I bought all 7 total. Quote Link to comment
yenpit Posted December 2, 2020 Report Share Posted December 2, 2020 I have a 1974 cluster available. PM sent! TJ Quote Link to comment
oukippy Posted February 27, 2023 Report Share Posted February 27, 2023 On 12/1/2020 at 12:25 AM, Phatjimmy said: I saw that post about the alternator not charging if you use an LED for the idiot light. Weird that Nissan would use the idiot light as a means of excitation for the alternator regulator. I will leave that one a conventional bulb. I will try and get to Napa on Wednesday and see if what they have as a twist lock socket fits this cluster. I may be missing it, but has anyone made a part number list with OEM and worthy aftermarket parts for our trucks/cars? Something that could be posted in the technical area. I know I have been pulling out what hair I have left trying to find various parts for this little truck. Hello, I'm working on an 1973 European 510. The Instrument Panel lights are T10 and I will change them with LEDs. Is it the same problem identified with the 510 ? And sorry for my question but what do you call the charge light ? Thank you! oukippy Quote Link to comment
iceman510 Posted February 27, 2023 Report Share Posted February 27, 2023 Charge light or battery light is fine. It should be the same situation for the 510 if you try to use an LED for that light. The circuit for that light is basically voltage at both sides, one from the battery and the other from the voltage regulator (essentially from the alternator). So the bulb illuminates only if there is a lack of voltage on one side (such as battery no good or low, or alternator not charging) allowing current flow. That is why it glow just slightly and not be fully on if charging is happening, but not full capacity. Quote Link to comment
oukippy Posted February 27, 2023 Report Share Posted February 27, 2023 20 minutes ago, iceman510 said: Charge light or battery light is fine. It should be the same situation for the 510 if you try to use an LED for that light. The circuit for that light is basically voltage at both sides, one from the battery and the other from the voltage regulator (essentially from the alternator). So the bulb illuminates only if there is a lack of voltage on one side (such as battery no good or low, or alternator not charging) allowing current flow. That is why it glow just slightly and not be fully on if charging is happening, but not full capacity. Thank you for the explanation. Another quick question: For the turn signals on the instrument panel, could you tell me if the lamp are connected like on the following picture? I think it is the correct way but I need a confirmation ( I don't think the 510 is a ground connection car). Quote Link to comment
]2eDeYe Posted February 27, 2023 Report Share Posted February 27, 2023 That is correct. The body is negative and the positive is the nub. 1 Quote Link to comment
datzenmike Posted February 27, 2023 Report Share Posted February 27, 2023 The LEDs dash lights I bought from Amazon were not affected by polarity, which was a relief. Pretty sure they are not dim-able though brighter is what I wanted as the stock lights are terrible on all Datsuns. It's impossible to read the odometer at night. I think I left the turn signals, charge and brake warning lamps alone as they are a brighter bulb than the dash lights to begin with. 1 Quote Link to comment
victhewhimpykid Posted February 28, 2023 Report Share Posted February 28, 2023 9 hours ago, datzenmike said: The LEDs dash lights I bought from Amazon were not affected by polarity, which was a relief. Pretty sure they are not dim-able though brighter is what I wanted as the stock lights are terrible on all Datsuns. It's impossible to read the odometer at night. I think I left the turn signals, charge and brake warning lamps alone as they are a brighter bulb than the dash lights to begin with. I put LEDs in my gauge cluster and in the fiber optics and the dimmer switch works perfect dimming them. Like you said I always keep them at the brightest setting. Quote Link to comment
ducky Posted March 12, 2023 Report Share Posted March 12, 2023 (edited) since we are reviving old posts a bit here, the NAPA LS6501 sockets cross to a bunch of other sockets. RockAuto has them for much cheaper than NAPA. OEM / Interchange Numbers: 2496279, 2973932, 5655006, 8122474, 8126900, 88860434, E6FZ13B764A, S503A edit: And if you didn't already have a reason to buy new sockets, I just tested the LED bulbs I had laying around that I bought for my Subaru in one of the other clusters I have. I inserted the new bulb, and that socket immediately cracked. Edited March 12, 2023 by ducky Quote Link to comment
six2ohyea Posted March 12, 2023 Report Share Posted March 12, 2023 18 hours ago, ducky said: since we are reviving old posts a bit here, the NAPA LS6501 sockets cross to a bunch of other sockets. RockAuto has them for much cheaper than NAPA. OEM / Interchange Numbers: 2496279, 2973932, 5655006, 8122474, 8126900, 88860434, E6FZ13B764A, S503A edit: And if you didn't already have a reason to buy new sockets, I just tested the LED bulbs I had laying around that I bought for my Subaru in one of the other clusters I have. I inserted the new bulb, and that socket immediately cracked. Do you have the RockAuto link? Quote Link to comment
ducky Posted March 12, 2023 Report Share Posted March 12, 2023 29 minutes ago, six2ohyea said: Do you have the RockAuto link? The reason I only provided those OEM numbers was because if they stop selling the ones linked below, it'll just be a broken link for someone in the future. Rockauto will actually cross reference a ton of numbers in their search field if you haven't selected a vehicle yet. https://www.rockauto.com/en/moreinfo.php?pk=2456706&jsn=728 2 Quote Link to comment
six2ohyea Posted March 13, 2023 Report Share Posted March 13, 2023 Trying to prepare for the LED upgrade. How many LEDs and sockets do we need in total? Quote Link to comment
]2eDeYe Posted March 14, 2023 Report Share Posted March 14, 2023 A 10 pack of each style will get you more than enough. https://www.amazon.com/s?k=led+194&i=automotive&crid=PMHKRJXIPRCT&sprefix=led+194%2Cautomotive%2C154&ref=nb_sb_noss_1 1 Quote Link to comment
ducky Posted March 16, 2023 Report Share Posted March 16, 2023 i got those handy packs in from Rockauto today. I must have missed where it said they were 2-packs. Now I have 14 lol They work fine as far as going in the old hole. I'll put them into the cluster in the truck this weekend. Quote Link to comment
six2ohyea Posted March 17, 2023 Report Share Posted March 17, 2023 You can send me the extras. Lol Quote Link to comment
ducky Posted March 18, 2023 Report Share Posted March 18, 2023 6 hours ago, six2ohyea said: You can send me the extras. Lol only if you go to turner salvage in fresno and make them put the cab they pulled for me over a year ago onto a pallet so i can PAY THEM AND GET IT SHIPPED HEREEEEEEEEEEEEE Quote Link to comment
six2ohyea Posted May 31, 2023 Report Share Posted May 31, 2023 On 3/12/2023 at 2:02 PM, ducky said: The reason I only provided those OEM numbers was because if they stop selling the ones linked below, it'll just be a broken link for someone in the future. Rockauto will actually cross reference a ton of numbers in their search field if you haven't selected a vehicle yet. https://www.rockauto.com/en/moreinfo.php?pk=2456706&jsn=728 So I purchased these along with these :LEDs and my instrument lights are not working. Any thoughts on troubleshooting? Quote Link to comment
datzenmike Posted May 31, 2023 Report Share Posted May 31, 2023 Turn the dimmer switch all the way to the right. Quote Link to comment
six2ohyea Posted May 31, 2023 Report Share Posted May 31, 2023 21 minutes ago, datzenmike said: Turn the dimmer switch all the way to the right. I did.. seems like all the lights that weren’t LED are still working. Quote Link to comment
Crashtd420 Posted May 31, 2023 Report Share Posted May 31, 2023 7 hours ago, six2ohyea said: I did.. seems like all the lights that weren’t LED are still working. Flip the led around.... sometimes they only work one way.... Leave a regular bulb in the charge light socket.... sometimes the alternator doesn't like the led... 1 Quote Link to comment
datzenmike Posted May 31, 2023 Report Share Posted May 31, 2023 I put LEDs in my 710 and I checked. They worked in both positions. 1 Quote Link to comment
Crashtd420 Posted May 31, 2023 Report Share Posted May 31, 2023 21 minutes ago, datzenmike said: I put LEDs in my 710 and I checked. They worked in both positions. Must have been the type you bought because the ones I bought only worked 1 way.. Quote Link to comment
six2ohyea Posted June 3, 2023 Report Share Posted June 3, 2023 Ok so flipped my LEDs and still not working. Just to cross check I purchased these: led lights: Yorkim 194 LED Bulbs White 6000k Super Bright 5th Generation, T10 LED Bulbs, 168 LED Bulb for Car Interior Dome Map Door Courtesy License Plate Lights W5W 2825, Pack of 10 https://a.co/d/hHIjLon led sockets: https://www.rockauto.com/en/parts/standard+motor+products,HP4090,instrument+panel+lamp+socket,21404 Quote Link to comment
