McFerg Posted November 28, 2020 Report Share Posted November 28, 2020 Hey Ya'll. 86' 720. I have been needing to fill my clutch fluid reservoir every couple of days. Then I let it sit for a couple weeks and now the reservoir is empty and I can't get the clutch pedal to engage. Do I just need to bleed the clutch? and where does my clutch fluid go? I have not been able to find a leak in the line...Gracia. 2 Quote Link to comment
Draker Posted November 28, 2020 Report Share Posted November 28, 2020 1 hour ago, McFerg said: Hey Ya'll. 86' 720. I have been needing to fill my clutch fluid reservoir every couple of days. Then I let it sit for a couple weeks and now the reservoir is empty and I can't get the clutch pedal to engage. Do I just need to bleed the clutch? and where does my clutch fluid go? I have not been able to find a leak in the line...Gracia. check inside the cab 1 Quote Link to comment
KELMO Posted November 28, 2020 Report Share Posted November 28, 2020 ^^^What he said. Had the same thing happen on the 1200. Just had the rubber mats and it was easy to see...once I put my foot in the puddle. 1 Quote Link to comment
datzenmike Posted November 28, 2020 Report Share Posted November 28, 2020 Usually the slave, and things tend to run down hill. If everything is dry then it has to be inside the cab and the master seal has failed. Replacements are extremely cheap including quality. Try to find one made in Japan. 1 1 Quote Link to comment
McFerg Posted April 21, 2021 Author Report Share Posted April 21, 2021 Thanks for the info. I was able to find the puddle under the mat! replaced the reservoir and it is spectacular. 1 Quote Link to comment
